1000hp+ Turbo engine
Howdy
which stroker kit would you recommend to a 6.0L iron block
Makes stroke bore?
Someone would have 1000 + engines here!?
all tips are welcome
thanks in advance
Makes stroke bore?
thanks in advance
Yes he are from Sweden and I know him a little ! drive the monte carlo now!?
But I want to know if someone of you guys know what stroker kit you can rekomend me !?
I want to know if someone use some good stroker kit for low bucks?
If I say best stroker kit for the price then?
of course 1000+ arent cheap, but if some say that you dont need to buy that crank for 2000 and rods for 1500 etc
I think you understand where Im going
I gonna check those sponsors
there are plenty of people making 1000rwhp on stock crankshafts and forged rods/pistons. With high boost will they flex yes.... have there been many failures to date....? No.
How much power do you want to make? At around the 1000rwhp level the 4 bolt style heads are going to be the limit of keeping the head gaskets sealed consistently.
Thanx for your awnser
My plan was to use my PT88 and maybe 408 /427 stoker
Would rather run with a forge crank than my casted one, just in case..
So a mls gasket can not handle 1000 + even with arp head studs !?
most people here in Sweden running tuned cars running E85
The gaskets aren't the problem. The problem is the thin decks on the heads distorting when cylinder pressure is high. As far as turbo choice goes, I wouldn't run a t4 on a 400+ ci motor.
I am running a 5.3 out of a 04 Tahoe, stock crank, forged h beam rods, forged pistons, stock heads with heavier valve springs and ported and polished, 7.9:1 comp, 110 oct. 950 cfm blow thru carb and twin Hx35 turbos pushing 28 lbs of boost and turning just over a 1000hp at 1028hp@ 6500 rpm, total build cost about $3500
