Anyone with experience using BW S475 T4?
Old 10-07-2012, 05:08 PM
DarkHorse's Avatar
Default Anyone with experience using BW S475 T4?
I have a T4 S475 1.25 a/r that's going on a 370" LQ4 in a 3100lb Mustang. What can I expect from this turbo as far as spool time, power or ET, when will it become a restriction for me? There's a lot of threads with the S475 with T6 but I went with the T4 for packaging purposes.
Thanks
Old 10-07-2012, 05:46 PM
mike13's Avatar
Do a search for forum member hellbent and his threads, I think he ran one on a lq9.
Old 10-07-2012, 11:21 PM
a-low's Avatar
I curious about this too. Whats the size difference between the two?
Old 10-08-2012, 02:27 AM
SirNemesis's Avatar
I'm running one on a 390ci engine. Works fine for me.
Old 10-08-2012, 06:34 AM
black6spdz's Avatar
I am running one on my LQ9 in my Silverado SS and it has been working great. Spool is good, it is a little lazy at part throttle but that is what i wanted since I tow with it as well. The truck has gone 11.7 so far on a bone stock motor in a full weight awd truck.
Old 10-08-2012, 10:43 AM
turbocamaro125's Avatar
its gonna spool super fast. I have a buddy with a s472 t6 on a 4.8 with 4l80 and it spools fast on it....so you have have a stump puller
Old 10-08-2012, 10:44 AM
and denmah has used the same turbo on a 4.8 and 5.3
Old 10-08-2012, 10:47 AM
https://ls1tech.com/forums/forced-in...oost-88gt.html
Old 10-08-2012, 10:55 AM
robsquikz28's Avatar
my t4 s475 made 850 to the motor on lt1!
Old 10-08-2012, 11:06 AM
^^^^^What boost did it take?^^^^
Old 10-14-2012, 12:49 AM
a-low's Avatar
Op do you have any pictures of the turbo? Im Interested in the dimensions as im almost
positive ill be getting the same turbo. Thanks.
Old 10-14-2012, 06:40 AM
Hank Peabody's Avatar
I had one on a 6.0 LQ4 and it spooled fast, went 115/145 16# a little under 3300#. The wheel sizes(83mm turbined one) are almost identical to T4 GT4202 and PT76 (76gts and 7675)
Old 10-14-2012, 11:43 AM
Originally Posted by turbocamaro125
^^^^^what boost did it take?^^^^
18....
Old 12-03-2012, 09:33 PM
DarkHorse's Avatar
Thanks for the responses all - i've decided to send it back to FI and have it upgraded to the 80/87 version, possibly with a race cover as well.
Here's a pic or two of the turbo
Old 12-04-2012, 11:21 AM
burbalanche's Avatar
Where did u get it from?4"dp and 3" cold side?
Old 12-04-2012, 02:17 PM
Moderator
denmah's Avatar
yep its a beast.
Old 12-05-2012, 10:35 PM
DarkHorse's Avatar
Which cars did you have it on denmah? I've been following all of your projects for a long time.
4" downpipe 3" coldside - correct
Old 12-06-2012, 11:05 AM
Where did u pick it up?
Old 12-06-2012, 06:08 PM
DarkHorse's Avatar
Sorry, forgot to mention that one
Jose @ ForcedInduction
PM DrTurbo and he'll set you up, great service - I have nothing bad to say about them.
Quick Reply: Anyone with experience using BW S475 T4?
