220/220 114lsa cam? Boost friendly?
I ran that cam NA and boosted. Very drivable, I would call it decent. But unless you already have it or can get it dirt cheap I'd go with something else. You need less overlap.
It spins up fast, but lets too much boost blow through at mid and upper RPMS. It helps counteract the lack of low rpm boost with a centrifugal blower, but leaves too much on the table at the upper range. Also, not that this may matter, but your mileage will drop.
FYI I'm pulling out a 224/224 113.5 and replacing it with an LS9.
Car:
1999 Trans Am WS6
Full interior
6pt wolfe cage
Engine:
forged aluminum ls1 or cast iron Lq4 (maybe 402? maybe stroker?)
317 head
918 springs
tsp chromoly pushrods
ported ls6 oil pump
different timing chain?
arp head bolts
power adder:
procharger f1 with fmic @10lbs or so
fuel:
255 pump
60lbs flow matched injectors
Tranny:
Stage 2 or 3 tick/rpm built
monster 3 clutch kit
pro 5.0
Exhaust:
Kooks 1 7/8 headers
cutouts after headers
custom 3" TDs
Rear:
MWC or Moser 9 with 3.90-4.11ish
stock width back brace
hardered studs
Wheels:
Weld Prostars
15x4 withh Goodyear front runners
15x10 with 28" Mt Et slicks
Driver:
my sorry ***
Goals:
stupid numbers with decent gas mileage
10 seconds or less
hows that sound?
1999 Trans Am WS6
Full interior
6pt wolfe cage
Engine:
317 head
918 springs
ported ls6 oil pump
arp head bolts
power adder:
fuel:
255 pump
Tranny:
pro 5.0
Exhaust:
Kooks 1 7/8 headers
custom 3" TDs
Rear:
hardered studs
Wheels:
Weld Prostars
Driver:
my sorry ***
Goals:
10 seconds or less
hows that sound?
Like you need to buy a better fuel pump... and call someone who knows blower cams.
A 220/220 in that motor... wouldnt fall out of a tree..... and itd be even worse if the motor was a stroker.
I would start.... at 231/243.... bigger cubes.... 239/251.
