Turbo 5.3 problem - please give opinions on my spark plugs (pics)
Recently gave my turbo 5.3 a few good rips and on the last pull, it felt like it was hesitating. Pulled into a gas station and saw a bit of compression blowing out of my oil cap breather, and the antifreeze was bubbling in my overflow container. Temp gauge showed 210* and oil press was normal the whole time. Did a compression check and all cylinders were between 135 and 145 PSI except 3 and 5 which were both 60 psi. I am hoping and praying it's just a head gasket but I have a feeling I lost a ringland...hope for the best, expect the worst is what they say. My oil was clean and my antifreeze looks clean as well. Gave the car another rip on the way home after this happened and it felt strong, but there is still noticeable compression coming out of the breather. Thoughts or opinions?
Heres a few shots of the plugs. Never seen the yellowish/green tint before, but I have heard thats normal from the cleaning agents in gasoline.
Cylinders 1, 3, 5, 7
cylinders 2, 4, 6, 8
Ignore the black soot on the ceramic outer part of the plugs. I had a pass side exhaust leak from the manifold.
Id say you lifted between 3 and 5 and the outer water jacket, chance pistons are alright going by the plugs are still intact
Before you pull the head i would do a leakdown to verify you have low compression because you are leaking from cylinder to cylinder
Nope, straight 93 pump
So basically if it was just the head gasket that blew, there would be no blowby through the breather? I pulled the head and the pistons are all perfect from the top, but I know the damage can be underneath as well. I just want to be sure that if I pull the motor, it actually is bad rather than do all the work and find out it's fine.
usually will lift outboard though
should easily be able to tell from the gasket and deck surfaces to see where it was leaking
The head surface and head gaskets both looked fine. Not really sure if I'm missing something, but nothing looked out of place...no cracks, melted areas, etc on either. I did notice what looked like a very fine scuff on the cylinder wall of #3, but you can BARELY catch a finger nail on it.
Nope, no smoke at all out the tail pipe
I'm posting a few pics of the cylinder wall and head gasket. Maybe some of you will see something that I'm not.
Heres the mark on the wall of cylinder 3
Heres cylinders 3 and 5 and the area between them
Close up. You can see it looks like the intake valves were slightly touching the pistons as well. Odd since they are 317 heads and a stock LS6 cam??
One side of head gasket between 3 and 5
Other side of gasket between 3 and 5
ring land... I just bought a 5.3 that was boosted, he drove on the car for awhile and it felt fine.. took it too the dyno, graph was out of wack.. did a compression test, #7 had 60PSI.. drove home just fine, i took it apart and sure enough.. ring land.
Lotta timing for pump gas! sucks, i know you just got this car on the road.
drop the pan pull those two pistons drop in two used/new ones and lower the timing to 16 at that boost and have at it again. im sure you will find cracked ring lands down low probably from butting the rings, i like to gap the top ring a little on these junk yard motors.
