Turbo recomendation for my motor!
Old 10-17-2012, 09:18 PM
o2ws8's Avatar
Default Turbo recomendation for my motor!
So this is my motor and im looking to add a turbo to it.
GM 6.0L Iron Block with Stainless Steel O-ringed Deck 370 cubic inches Lunati Billet StockStrokeCrankshaft Callies Billet MainCaps ARP MainStuds Lunati Pro Billet Connecting Rods ARP 2000 Connecting Rod Bolts Wiseco 8.8:1 Custom Forged ThickCrown Turbo Pistons Total Seal Piston Ring Set Rollmaster Heat TreatedDouble RollerTiming Chain w/Torrington Bearing Ported Hi Volume oil Pump Comp Cams 224/ .588" Turbo grind Camshaft Comp Cams Lifters Comp Cams Hardened Chromoly Pushrods ARP 12pt Head Stud Kit Stage 3 Fully Ported LS6 Cylinder Heads, Stainless Valves,330+cfm Jesel Valvetrain 1.7 Roller Rockers.
I want to try and make atleast 800 horsepower or more if possible just looking for the right turbo.
Old 10-17-2012, 09:21 PM
jridenour31's Avatar
T4 or t6? Budget?
Old 10-17-2012, 09:49 PM
o2ws8's Avatar
Really right now just trying to weigh my options and see what best will work with my motor and make good numbers... Not trying to go wild budget wise.
Old 10-17-2012, 09:54 PM
ricky6991's Avatar
I love this crowd... theres so many posts for 800hp ect that all end with "on a budget" lol.
Dont mean anything bad by saying that only because somehow people do it on these motors.
Old 10-17-2012, 09:56 PM
o2ws8's Avatar
Im just saying im starting with a budget but that goes out the window quick lol
Old 10-17-2012, 10:04 PM
ricky6991's Avatar
Oh yeah im sure you end up with the best you could get for your senerio even though your hoping someone can show you where to get it for cheaper. Lol its inevitable. Atleast these motors have proven themselfs to make it worthwhile. Btw, i have complete turbo kit for CHEAP but its a bw s472 which you may want bigger.
Old 10-17-2012, 10:20 PM
o2ws8's Avatar
Just trying to see what people might recommend me for my setup... If its cheap great if not no big deal just trying to have a good kit and make good numbers. Yea im looking to maybe getting a 78 or 88 not sure yet.
Old 10-17-2012, 10:22 PM
LS1NOVA's Avatar
There is a lot more to picking a turbo than the engine specs. What are you planning on doing with it? Going 8's or to Dairy Queen?
Not knowing anything Id say Garrett GT50-88
Old 10-17-2012, 10:31 PM
o2ws8's Avatar
Im looking for 9's and maybe some street fun when possible.... Its an automatic! I have a 200r4 tranny.
Old 10-18-2012, 07:16 AM
Sarg's Avatar
I would start with a borg s480 with the 96mm turbine and 1.32 housing and if you need more jump it up to the 88 or something in that range. Just my .02
Old 10-18-2012, 08:15 AM
SPRAYED 01's Avatar
Is it an fbody? whats the race weight and its important to know the space your working with. I would say pt88, bw w/96mm turbine,gt50_88.
Old 10-18-2012, 10:07 AM
o2ws8's Avatar
Yes its for an F-body the one in my sig.Not sure on weight but i dont any bumper supports in he front and also getting rid of the ac.
Old 10-18-2012, 10:17 AM
S480 with 96mm turbine
Old 10-18-2012, 10:36 AM
Calypso's Avatar
I'm building almost the same motor. Forged 6.0, 9.8cr, E85. I'm going with twin Comp billet 6067's because I wanted the snappy, instant throttle response on the street, and enough turbo to make 750-850rwhp or more if I want. If you'd rather have max top-end hp, then most people go with a big single.
Old 10-18-2012, 11:01 AM
Sweet_SS's Avatar
This is what I'm going with
http://www.forcedinductions.com/productsborgwarner.htm
S400SX-80 w/ 92 mm turbine wheel an AR 1.10 T4
Old 10-18-2012, 11:10 AM
Sarg's Avatar
I did the same turbo and turbine wheel but the T6 1.10 housing on my 5.3
Old 10-18-2012, 07:51 PM
o2ws8's Avatar
Thanks guys... Ill shall see what i decide to go with... Does anyone know what kinda numbers it would put d1own 80mm?
Old 10-18-2012, 08:52 PM
Plenty to go 8's.
Old 10-18-2012, 09:55 PM
o2ws8's Avatar
Well then that should be enough for me.. Ill be happy with 9's and an 800hp auto car.
Old 10-18-2012, 11:13 PM
9 Second Truck Club
stock48's Avatar
Hard to beat the S480 for power vs $... If going T4 a S478/92/1.25 wouldn't be a bad choice. S478 wheel is light and spools fast.
Quick Reply: Turbo recomendation for my motor!
