Borg Warner
Old 10-26-2012, 07:53 PM
knuts82's Avatar
Default Borg Warner
Anyone know if this would work on a 4.8
http://www.ebay.com/itm/Brand-New-BH...7411b6&vxp=mtr
Old 10-26-2012, 08:10 PM
dmaxvaz's Avatar
why not? it will be a tad laggy, but will work nice with a 3200+rpm stall. it is not a bad pc, alot of guys use them in a compound turbo kit on the 5.9 cummins.
Old 10-28-2012, 09:00 PM
knuts82's Avatar
Anyone know about what this is their is no turbine info. AR?
s475?
Old 10-29-2012, 01:07 AM
o2camaross's Avatar
Is it a T4 housing? I cant seem to find any info on the turbine or housing
Old 10-29-2012, 06:27 AM
Sarg's Avatar
Send him a message and get more info....turbine and compressor specs, etc.
Old 10-29-2012, 09:57 AM
Turbochargershop's Avatar
It's a T6 exhaust with a 5 inch outlet. The Compressor wheel measures 73.5 x 107.1mm. The turbine wheel measures 97.23 x 86.23mm. He shows it has a BW number 167713 with a 26cm exhaust housing, But Borg Warner shows the 166713 has a 32cm exhaust which is 1.30 A/R
Old 10-29-2012, 10:52 AM
Sarg's Avatar
Probably work pretty well. Turbine housing it a touch large if it is a 1.32 but not terrible. The turbine is well suited but a tad large. I would guess it would be good for 700 if you lean on it.
Old 10-29-2012, 11:07 AM
91sonomast's Avatar
With that 1.32 A/R that turbo won't make full boost until high in the RPM's, correct?
Old 10-29-2012, 11:40 AM
rotary1307cc's Avatar
Meh be fine,
Its the old ht3b
Reverse rotation, keep that in mind if you want to change ever
Old 10-29-2012, 01:11 PM
o2camaross's Avatar
That thing is huge! Seems to be very comparable to a S475, why so much cheaper?
Old 10-29-2012, 02:36 PM
T76s10's Avatar
Kind of off topic but i sent your heads out last Thursday. I don't go on Ebay much so i never replied to you when i sent them. I just seen your name on here and realized you were the one who bought them.
Old 10-29-2012, 04:34 PM
knuts82's Avatar
Yeah I just got the heads I think ill finish porting them do a valve job and springs and see what they do. I have a few sets that im going to try just to see what is better.
Old 10-29-2012, 05:09 PM
knuts82's Avatar
So anyone have an opinion on what would be a better turbo choice this BW or a On3 76mm I already have some On3 .96ar units but was looking for somthing with a bigger turbine. Motor is a build 294ci forged pistons ect. currently with ported 706 heads, .6xx lift turbo cam, Its currently backed by a muncie 4 speed but going with a Glide and a 4000ish stall. I also have a garrett 4202 I could get from a buddy. Motor will be running a blow thru e85 setup. Thanks....
Old 10-29-2012, 06:11 PM
jridenour31's Avatar
The bw will be much better.
Old 10-29-2012, 06:16 PM
Sarg's Avatar
Agreed. I like the BW units and they will flow a good bit more air with the larger turbine.
Old 10-29-2012, 06:19 PM
knuts82's Avatar
I was checking around online and found 6 more of these BW turbos for less than $400 shipped. I might just pick one up and try it for that price.
Old 10-29-2012, 06:32 PM
T76s10's Avatar
yeah we focused on the exhaust ports so those are pretty much good. the intakes we didnt touch because they had some gunk in them.
Old 10-30-2012, 04:32 AM
If you wouldn't mind post/pm those links to those other turbos. I would like to see them has those prices are way less than BW sells them for. I see that the one on Ebay says it's a BW turbo, But I see no part number on the compressor cover or a factory tag on the bearing housing. That's what alot of overseas stuff looks like. Not saying it is, Just curious.
Quick Reply: Borg Warner
