Going for MOAR power, new motor and MOAR goodies! gen IV 5.3 & tc78
Old 11-03-2012, 07:20 PM
Fondle's Avatar
Default Going for MOAR power, new motor and MOAR goodies! gen IV 5.3 & tc78
Popped the old iron block 5.3 on the dyno last go around, broke a ring land on piston #7. So naturally its time for an upgrade
Here was my old setup-
And here is the upgrades in the new setup
-gen IV aluminum 5.3, uses the newer LS3/LS2 components and should be a stronger motor, also dropping 100lbs on the front end couldnt hurt
-Cooling Mist boost activated deluxe kit with their super atomizing injector and solenoid upgrade
-Patrick G custom ground cam 22*/22* 60*/60* @ 115+ 4
-Deatsch Werks 96lb injectors
-Deatsch Werks Fuel Pump
-96mm Maf Housing
-LS3 Maf
Other Info-
-Ported/ Milled 317 heads should be around 9.7 CR
-Fast 92/92
-TC78 turbo, custom with a 3.5 " downpipe and a .96 a/r
-ls7 Lifters
Just got the motor dropped in, waiting for my new front cover to come in so i can finish assembling everything
Its been a learning process on figuring out what all i needed to make this Gen IV motor work. but i think i finally got it all figured out
Old 11-26-2012, 08:09 PM
Fondle's Avatar
Meth tank mounted
solenoid mounted behind the headlight
Injector mounted
New 96 mm Maf Housing and LS3 maf
View from under the car of the wastegate
Car is all back on the road now, and undergoing some street tuning one my trips back and forth to work
Old 11-26-2012, 08:23 PM
ronnieforrester's Avatar
lo0ks good
I like the carb engine lift plate- did you have to redrill it or did it line up ?
Old 11-26-2012, 08:40 PM
Fondle's Avatar
it lined up for the most part, i just made them i tad bit bigger and everything lined up
Old 11-26-2012, 11:13 PM
alexcoreas's Avatar
When does the Turbo start to spool? Im still gathering parts for my build. Hope to see some vids soon.
Old 11-26-2012, 11:40 PM
WheelsUp84z's Avatar
any shots with the hood closed? My charge pipe is roughly in the same spot, just wondering if it sticks through the top of the hood, or if you had to notch the underside of the hood. Just a quick pic of how mine is setup.
Old 11-27-2012, 06:27 PM
Fondle's Avatar
no modifications done to the hood at all, hood fits like normal
Old 11-27-2012, 06:55 PM
Ryans99ls1's Avatar
what all did you have to do to get the gen4 to work? just curious. Car looks great.
Old 11-27-2012, 07:08 PM
QuickShift's Avatar
Nice looking setup. Any numbers yet? Love the RTS wheels.
Old 11-27-2012, 07:11 PM
Fondle's Avatar
ls3 valley cover
ls3 corvette front cover
lingenfelter converter box
relocate knock sensors and extend wires
Old 12-12-2012, 08:37 PM
LT1RAY's Avatar
Any updates?
Quick Reply: Going for MOAR power, new motor and MOAR goodies! gen IV 5.3 & tc78
