which spark plugs for e85 and mp122 maggie
Old 11-04-2012, 11:53 AM
supershift67's Avatar
Default which spark plugs for e85 and mp122 maggie
I bought the NGK 4177 v-power spark plugs (tr6)and after looking at them I see the electrode sticks out pretty far. I also don't like the sharp edges on the v electrode. any thoughts on spark plugs or will these work? I should be around 9psi boost wise if i am lucky.
Old 11-04-2012, 01:57 PM
LT1RAY's Avatar
TR6's gapped at .35 and you'll be set.
Old 11-04-2012, 06:15 PM
alright,thanks
Old 11-04-2012, 09:30 PM
fotoboy's Avatar
I still run the tr6 but gap them tighter at .028. Lots of guys are switching over to br7ef plugs.
Old 11-04-2012, 11:17 PM
Grr
Grr's Avatar
I would run 8's, no performance increase by running the hotter 6's and you might be able to sneak in a little more timing. What I use on all my LSx stuff and even my NA stuff is
NGK R5724-8
which is a non projected 8 range plug, its perfect for boosted stuff even with E85
Old 11-05-2012, 12:11 AM
fotoboy's Avatar
No way he needs a heat range 8 for e85 and maybe 500 whp. I'm a 6 and put down 730 and plugs look just fine.
Old 11-05-2012, 12:23 AM
Grr
Grr's Avatar
ive ran 6s on E85 up over 800whp, not something I would do again as there is no benefit only negatives.
My NA setup actually went a few hundredths faster and .4mph more switching to 8's at the track with no other changes. Got rid of any knock I was getting and after was able to add 2* timing and pick up more
Quick Reply: which spark plugs for e85 and mp122 maggie
