supercharged with a wastegate
I am running a wastegate and bov on my ysi set up. My problem is that it will only make 5 psi. And I'm pretty sure that its not belt slip. I think that either the wastegate or bov us bleeding off boost. I'm running the standard size vacuum line right off the intake to the bov and wastegate... Is this ok or do I need bigger line or do I need a bigger vacuum source like the vacuum line going to the brake booster ?
The vacuum source should be fine as long as its tee'd from one line on the intake to two seperate lines going to each.
If you have a 18# pulley setup or something on there and its only making 5# then yes one of them is not working properly.
If either valve is leaking, you should hear it.
And I would run dedicated lines to the BOV and W/G
Although depending on how you have them configured, it could explain the lack of boost.
How much boost, and at what rpm's does it make the boost ? And does boost rise with rpm, or does it level out at any point ?
And again, how do you have the BOV and W/G lines etc configured. And if you are trying to make say 15psi, why do you have a wastgate connected at all ?
What you're doing seems to be correct.
I would find an alternative solution to tee-ing all those hoses though and run dedicated lines where possible.. And for the BOV and W/G I'd run a 1/4" ID rubber hose the entire length, trying to make any hose runs as short as possible.
Blowing into the top port of the w/g should ensure it stays shut. Likewise with the BOV, and as it has a weaker spring etc it will open when there is vacuum in the line. The BOV should be open at idle.
Apart from those small issues, the install looks sound.
So does boost rise in a linear fashion as rpm's rise ? If there was belt slip, it could rise, then level or fall. Likewise if the w/g etc was blowing open.
It's been so long since I only ran about 15psi or so, damned if I can remember what pulleys I used. Might have been around 8.25/3" or so, really cant remember
I just spin the **** out of it now and make it work lol.
Ive an 85T/28T on it. My 382 LS makes about 15psi at 4800-5000rpm. Although my unit is quite old now. I generally shift around 6700rpm.
Looking at my log the boost slowly climbs as the rpm rise. I am shifting at 5900-6000 I can try shifting at 6500 and see if I make more boost or if it just levels out. I have a 2.95 blower pulley I can use too. I had it on there before and it didn't make any more boost. Where did you buy your cog pulleys?
My car isnt a Camaro, and pretty much everything is custom made.
Although I think pulley offset etc will be pretty much the same as the generic Vortech stuff ( I am using a Vortech 28T upper )
Crank pulley in what respect ?
I just use a Powerbond damper with an adaptor to a custom made cog pulley. But I think the dimensions of this will be pretty much the same as the big black generic Vortech pulleys, as I copied it off that, although made alterations to minimise the size of the pulley ( ie it's only 52mm wide with no flanges and running a 50mm belt )
I guess that depends what your step size is. Dont think it's just as straightforward as that.
But if you have the pulleys it would be worth a try.
Also ensure your BOV isnt leaking, and there are no leaks in the plumbing anywhere
