Junkyard 5.3l turbo build, will this cam suffice?
I have a cam sitting in my garage from my early LS1 modding years. Its a 222/222 .556 .556 112 Will this cam be ok for a junkyard turbo build? I loved the way this cam sounded and produced such a flat tq curve. Wouldn't mind using it instead of buying something else...
That would be a good cam to use with a single turbo such as an On3 70/76mm
The mild exhaust wont overdrive the turbine.
The lobe sep creates a little more overlap than is typical of a cam that size.. thats where your sound is coming from somewhat.
Install it on a 107 or 108 intake centerline and let her go.
