T4 divided flange
Old 11-13-2012, 07:58 AM
ToxicWS6's Avatar
Default T4 divided flange
If you are going to block off one side of a T4 divided flange turbo to decrease spool time does it matter what side it is?
Old 11-13-2012, 08:43 AM
ttranssam's Avatar
Why n the hell would you wanna do that? It would choke the **** out of the motor
Old 11-13-2012, 09:33 AM
Ryans99ls1's Avatar
i would think he is talking about using a spool valve (i hope)
if you are using a spool valve, then no it doesnt matter because it will open back up once its the boost level you want
Old 11-13-2012, 03:58 PM
ToxicWS6's Avatar
sooo just looked up a "quick spool valve, and now that i know what a quick spool valve is, yes im going to use one, i originally was going to run a waste gate on one side set too 5 psi give or take, this obviously is the same idea just a better way to go, sounds like people have had great results with them
Quick Reply: T4 divided flange
