Does the truck hat on prochargers rob horsepower??
Looking for some ways to gain some extra horses and Ive heard some suggestions on this forum that the truck hat on the D1sc prochargers rob horsepower. Is there any facts like dyno testing to prove this?
Where did you read that? The standard kit hat is 3.5" diameter and makes a tighter bend than the 4" truck hat.
Any hat/filter combination will rob horsepower compared to no hat/filter or plain horn. But given the limited space between the blower inlet and radiator nothing is bigger and smoother than the truck hat, short of a custom molded piece.
The truck hat with a clean (large pleat) largest cone filter you can fit would be best. a 9" length filter with .5 pleat will certainly fit. If you have space underneath the headlight assembly (no pipe, fogs, cruise) you might be able to fit a 10" filter with 1.5" pleat. Its all about filter media surface area and keeping it clean.
I can't keep the truck hat on mine. It fell off the inlet the other day and grinded my rubber black cone that is in the middle of the impeller. Lucky for me none of the blades where damaged... Sucks I had to go back to my regular inlet hat that came with my d1 kit. I'm going to try and mold something up, so I can have the cone higher up away from the ground. As it sits now with the truck inlet the cone sits right above the ground and the truck inlet doesnt really fit right with the radiator right there. Ill keep everyone in the loop.
TT-TECH Veteran
Becareful useing just a silicone 90 as mine worked fine cold but once it got hot it would collapse and that is terible thing to do to a prochargers seals etc... I ended up cutting a piece off an Aluminum 90 to fit inside to keep it from being able to collapse and worked great for me. GL!
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
UNDER PRESSURE MOD
I found that you need to grind off the little lip that is on the edge of the outside of the end of the truck hat in order to get it to fit properly on the procharger outlet. Since the outlet lip is only about 1/2" wide, approximately the same width as the clamps, having that lip on the inlet hat not only pushed the clamp off the lip of the procharger, but the lip also kep the hat from seating all the way on.
See the picture below as to where I'm talking about that the ridge hits the procharger itself.
I had to do the same thing to my truck hat. Filed off the bump around the edge of the blower side of the truck hat. Before the clamp would squeeze the hat off the blower inlet. After removing the ridge the clamp and hat sit snugly against the blower and can be tightened down strong. Hasn't moved since.
