need your help of Turbonetics
i have 2001 DD turbo camaro T-56, 3.42's, 317's heads, 9.2cr 402ci
i am looking for 700-800 rwhp, is Hurricane 7868 turbo will work?
its T4 0.96 A/R, what do you think guys?
thanks
thanks
i was use TURBOCHARGER T4 GT45 Y2004K on my stock Ls1 bottom with 317 stock heads, its make 560rwhp/580rwtq
on 10psi @ 6k rpm
so my question is s475 and Y2004K same size? i mean when i replace my Y2004K with
s475 should i do some modifaction to fix that BORG WARNER turbo?
from where can i get it with nice cheap price?
thanks dear
on 10psi @ 6k rpm
thanks dear
to answer your question.... You can easily get 700-800 hp out of the pt7675 turbo. Being that your car is a 6 speed I would stick with the .96 ar. Stick with your original inclination.
i found one turbo with my friend but i dont know its specs?
its part number 177104 borg warner turbo
i think it is 1.10 A/R 'T4'
cold side 75
i am not sure but i have all number on it but how can i get the specs!?
thanks
cold side 75
thanks
jridenour31 is on the right track.
Sorry, thought I already replied to this. If that's what I think it is, it's the 83mm 1.1 t4. The Borg Warner's turbines are listed by the inducer instead of exducer like the Turbonetics and Precisions, so it's pretty much the same thing as a 7675.
You can get a t4 s475 with a 1.1 92mm turbine from Forced Inductions for $1300. That's what I would go with if you're dead set on a t4. If you can go t6 than you can get a standard s475 for about half that price but it may not spool too well with a t56.
The twins will spool better than a fairly large single. However, the turbo you just mentioned will certainly meet your goals and is considerably cheaper. There's more than one way to skin a cat. Just make sure you have enough turbine to support your cubes and enough compressor to support your power level.
twins will let me change all my setup piping, cooling system ,....etc, so i need single to spend little bit $$$
ForcedInductions says to me:
"Go with a 80/92 unit with a T4 housing. Will easily make 800+rwhp and spool extremely well with those cubic inches"
Your be able to hit 900rwhp if like with that pushing it, i would think.
I personally would like a bigger exhaust, but since your a 6 spd go with the t4 80 92
