th400 or PG/3.23's or 3.42's/28" or 29" tire? high 8 second car at 3600lbs
Old 11-18-2012, 03:14 PM
driven87's Avatar
Default th400 or PG/3.23's or 3.42's/28" or 29" tire? high 8 second car at 3600lbs
ok took the car to the track the other night for some test hits before turning up the boost and i ended up hurting the new th400 trans. previous the car had a th350 and has been 9.25 at 153.3 on 19 psi with 3.42's and 29" tire. i had planned to build a better rear over the winter and now it seems im gonna be doing trans work as well. i have thought about going to a power glide for ease of only having to shift one gear. i have also thought about keeping the th400 but putting 3.23's in the rear and going back to 28's. i have a blank slate to work with over the winter im just looking for some ideas. i know once i turn it up to around 24psi or so i think the th400 is gonna be walking a fine line for traction with stock gear set inside. im def leaning towards 3.42, powerglide and 28's but worried about will i be ok with 3.42's in the rear with the glide. thanks guys for any input.
Old 11-18-2012, 03:17 PM
Sales@Tick's Avatar
PG all the way. I'm a fan of the smaller tire stuff so I'd use a 28x10.50, 3.73's and a PG with an aftermarket 1.80 gear set.
Old 11-19-2012, 03:11 AM
skinnies's Avatar
glide IMO
Old 11-25-2012, 08:47 PM
GueSS Who's Avatar
Doubt very seriously if a glide will hold up at that weight. You need the extra gear in 1st to get the car going. I still have the 2.41 1st gear in my TH400 and have been 1.172 60ft weighing in at 3450. I thought about a glide but we have gotten the 400 to work for us. Plus you will spend twice the amount to get a good glide vs a 400 to hold the same amount of power.
We use 3.70 gears with it as well. I would like to go to a 3.89 but we already have had some issues keeping the car from wheeling. More overall gear will make that worse.
I have a glide in my TA. It have 1.80 rossler bad boy with 4.10 gears. Probably needs 4.30s for the 1/8 mile.
Both of these cars are on 275s.
Old 11-25-2012, 09:28 PM
Sales@Tick's Avatar
I use to agree with the more gear is better, but after seeing numerous big power cars like yours go on the bumper and have too many problems with launching trying to get a good number, the glide makes more sense.
I'll be using a glide in mine after too many problems either spinning or about going on the bumper myself this year.
Old 11-26-2012, 02:53 AM
BAKED's Avatar
Im running a glide in mine with 3:50 gear and 28" tall tires. The car is 3430 with me in it.
Had a problem keeping the front end down last time out, the car went towards the wall so I had to back out and it came down hard and cracked the oil pan..
On 16.5 psi I went 8.92 @ 159
Quick Reply: th400 or PG/3.23's or 3.42's/28" or 29" tire? high 8 second car at 3600lbs
