All Out Bonneville Junkyard Effort
We are looking at building a turbo 4.8 to run in a '32 Roadster at Bonneville. The class record (D Blown Gas Roadster) seems soft at 211. It takes about 800 horsepower to go 200 in that body that means we will need like twice that much to go 225, right...?
So what we are thinking at this point is a stock shortblock 4.8, twin Ebay GT45's, good valve springs, a custom grind cam, Victor Jr or Super Victor intake, custom elbow, the biggest throttle body we can find, 120 pound injectors, A2W intercooling, twin 044's. Run it all on MS3. The gas class means we run their gas which is C16. Methanol puts us in a fuel class so that's a no go.
The big deal here is that we need to run flat out for 7 miles. Two full minutes at or near full throttle. We also need to able to get in and out of it because traction on the salt is also a major issue. Being able to modulate throttle near the limit is important. I figure it would be cheaper to bring four or five craigslist 4.8's out there than to build one really, really good one. Any thoughts?
One bit of advice I would have is to drill a hole in the back of the head and run a -10 line to the oilpan to provide a good oil return to the pan.....I would also recommend a bit more fuel pump....For the price of 2 044's you can get a holley dominator twin pump which is rated for more flow.
Of course we have access to a dyno for tuning and a tuner who knows how to use it. That will certainly get us some useful information but there's no dyno like Bonneville. I build cars for a living and the other guy involved in this project drives a landspeed '32 coupe. He also builds motors and crews for two record holding '32's including the 291 mile an hour BMR roadster. This is not our first rodeo but still, there's always more to learn!
Is this going to run a stock oiling system or some sort of dry sump? Just thinking the windage may become an issue???? I am no expert but something to think about. Also, the coolant crossovers from head to head as to avoid any steam pockets. I am sure a search on here would provide some tips on the mods that guys have done to their cars to avoid this. Thats what comes to mind for me at least. Sounds like an awesome project.
Definitely wont need the biggest throttle body possible. There are lots of guys who have made 4 digit power on stock intake and throttle bodys. I think you could better spend the money elsewhere.
Why a 4.8 instead of a 5.3?
To make a record run do you have to make a follow up run for it to be official? Like in drag racing?
Captain Double Post
I dont see what everyones issues is,let that bad boy eat lol,do you already havve the 4.8? Some sponser on here has a deal on forged 5.3s,i think there around 2500,whichis a pretty good deal,there are alot of killer builds that people use 4.8s n 5.3s,make sure to do a build thread,imo it sounds like it will be pretty sick,
We are running a 4.8 to meet class rules. A 5.3 is a C motor and the record there is very high. To get the record you have to make the pass then the car goes into impound. You can do minor servicing while it's in impound but you can't swap motors or transmissions or gearing or anything like that. The next morning you have to back up the run to get the record. As for oiling the track, they make you tarp your pit to protect against oil and coolant but on the track they just let it ride.
The main issues I see have to do with longevity, it's a whole different deal than drag racing. The car spends a couple of miles fighting against the air at or near full throttle for those last few miles an hour. **** is under a lot of load. I like some of the oiling suggestions, anyone have other ideas?
One problem I see is if you plan on bringing extra shorts you should bring extra turbos as well unless you can keep pieces of piston from taking out the turbines.
And I'm still a little leary about a stock engine. I know people do it on dynos and 1/4 mile passes over and over but those are for seconds at a time your talking about 14 miles to make a record pass. That's 28 1/4 mile passes combined at one time just for a single pass . That's going to be ALOT of stress on that stock engine.
Very good point also
Plus Costco has Depends in bulk, so we have that covered.
Stock block and rotating assembly, twin turbo, 800+ hp, 2 minutes @ WOT? Is it just me or does anyone else see an issue here. There is no way that is going to hold up. That is an enormous amount of heat for those pistons to handle for that amount of time.
in for updates. Ford took the lincoln Mark 8 in '94, blue printed and balanced the factory 4.6 Dohc, lowered the air suspension, threw in some gears (to get the 4r70w to stay in 3rd, a 1:1 ratio), a cage, and a belly pan and went 186mph (iirc) with a (rated) 280bhp engine in a 3800lb car...... but its a damn lawn dart.....
