My car on dragzine!!
The 9.18 pass was on all stock 240 rear end and axles. I recently swapped in a q45 rear diff and beefier q45/300zx axles. Should be quite a bit stouter that the stock 240 stuff. I had broke a couple axles along the way and that should t be a worry now.
After the fuel system upgrades I still plan to run e85. If I was running gas I would have enough fuel system now.
My stall flashes to the 4500 range. Goes between 5900-6000 on the transbrake. I use a lingenfelter 2step and we were leaving at 3500rpms with about 7-8 psi. I'm thinking now I'll be able to leave a bit harder with the beefier rear end stuff.
