Turbo Support/Braces
Old 12-06-2012, 01:54 PM
cyipher's Avatar
Default Turbo Support/Braces
I plan on mounting my s480 right in the front center of the motor and am wondering what eveyone is using for a turbo brace to not have all the weight on the manifolds. I plan on using flex couplers so the turbo needs to be supported.
Thanks
Old 12-06-2012, 02:28 PM
Sarg's Avatar
Here's my junk. Just something I threw together with some metal I had around, but it works pretty well! That is a S480 as well. I'll try to snap another closer pic.
Old 12-06-2012, 02:32 PM
Sarg's Avatar
Little closer up:
Old 12-06-2012, 03:08 PM
F110Mech's Avatar
Just to add to this, where are people bracing them to the engine?
Old 12-06-2012, 06:11 PM
Sarg's Avatar
Heck were it me I would go off an accessory bracket bolt or something. Mine is just way too far forward and down to really do that.
Old 12-06-2012, 07:48 PM
LILHEMI's Avatar
im going to try and brace mine to the head. i need to brainstorm it a little bit but it should be pretty easy.
Old 12-06-2012, 08:29 PM
jridenour31's Avatar
Race Parts Solutions makes extended turbo flanges that you can bolt onto whatever bracket you make instead of welding directly to the flange. I used one and hard mounted my bracket to the frame rail.
Quick Reply: Turbo Support/Braces
