Edelbrock Vic Jr VS. Edelbrock Pro Flo XT
Old 12-12-2012, 08:19 PM
Wicked69's Avatar
Default Edelbrock Vic Jr VS. Edelbrock Pro Flo XT
I am trading straight up my Edelbrock Vic Jr. and Tall elbow for The Edelbrock Pro FLo Xt in Black Powder coat. The main reason is because of the straight up trade and the fact that I think the intake would look absolutely wicked with my Twins in my al ready 69 Chevelle called "Black Death."
A couple questions.
1. From a performance standpoint shouldn't this intake run just about as well as the Vic Jr? My car is a street and strip car but as long as I don't lose anything for the strip and maybe run a little smoother on the street I would be happy. Do you think they will run on the street and strip about the same?
2. I am running the Edelbrock Rails. Will those same rails work on the Pro Flo? Can I use the same gaskets that I am using from the Vic Jr. Basically I am trying to find out if this will be a direct swap?
Here is a picture of my car and engine compartment. I think the new Black Powder coated intake will look sick on this car and off set my paint job well. What do you all think? Waste of time or good swap?
Attached Thumbnails Edelbrock Vic Jr VS. Edelbrock Pro Flo XT-twin-on3-s-pic-2.jpg   Edelbrock Vic Jr VS. Edelbrock Pro Flo XT-car-finished.jpg
Old 12-12-2012, 10:04 PM
93camaro_zzz's Avatar
1. Yes it will run just as well. The current LSX record holder used the pro-flo XT on his race car for quite a long while at power levels over 2000hp and it seemed to do just fine.
2. The edelbrock rails SHOULD work. I have those same rails on my pro-flo setup. To make completely sure though, check out edelbrock's website and see the part number on the rails the recommend.
Good luck, and enjoy the new intake! I sure as hell do!
Old 12-12-2012, 10:15 PM
Wicked69's Avatar
Thanks man. That is what I wanted to hear. I definitely think these things look bad ***. The winter is a good time to "clean" up my engine compartment area with the new intake and "tweaking" things a little.
Old 12-12-2012, 10:52 PM
killernoodle's Avatar
Off topic: that car looks gangster, man.
Old 12-12-2012, 10:54 PM
V-seriesTech's Avatar
Badass chevelle.
Old 12-12-2012, 11:09 PM
Wicked69's Avatar
Thanks. I hope that the intake looks just as sweeeet once I get it on.
Old 12-12-2012, 11:16 PM
typhoon1015's Avatar
it will look cool, why not?
Old 12-12-2012, 11:33 PM
GarrettM's Avatar
Omg that car is sick! Also plus 1 for the pro-flo. After hours of research ive decided its the way to go. Guys are having great success with it on the street as well as the track.
Old 12-13-2012, 12:24 AM
Old 12-13-2012, 08:04 AM
71 chevy's Avatar
who is the current record holder?
Old 12-13-2012, 08:08 AM
edge04's Avatar
You got any more closer pics of the engine bay?
Old 12-13-2012, 08:11 AM
JAX04's Avatar
Currently its Andreas Aurtherson (spelling?), bad *** monte from over sees.
Old 12-13-2012, 08:21 AM
jridenour31's Avatar
Car looks nasty. No help but the pro flo definitely looks better.
Old 12-13-2012, 08:32 AM
RedRocketZ28's Avatar
First time I have actually seen a good picture of your car. That thing is completely bad *** looking.
I have been researching the Pro-Flo a bit, and it seems to work very well with boost. I plan to pick one up once I get a bigger turbo.
Old 12-13-2012, 09:10 AM
Wicked69's Avatar
Thanks for the input all. I will be sure to make posts of the swap. I may even clean things up a little while I make the swap. Typhoon-The pro flo looks sweeettt.
Old 12-13-2012, 12:07 PM
Tjabo's Avatar
How do these compare height-wise with the Holley Hi-Ram? It looks like the Edelbrock is a little less expensive and probably more streetable for an N/A application, huh?
I specify N/A application because I'm not really sure streetable is a concern when a turbo is in the system... Since they pretty much always provide mild amounts of positive pressure they throw intake tuning out the window to some degree...
Old 12-13-2012, 12:59 PM
Yeah it is "camaroandreas" on this board. I believe the overall record is a 6.71. I don't remember the mph. But Mark Carlyle is getting EVER so close with his IRS orange corvette car. He has run a 6.84.
Old 12-13-2012, 01:44 PM
Sales@Tick's Avatar
I never knew Andreas ran a XT until now. News to me for sure!
Old 12-13-2012, 02:21 PM
his XT was stock cast, but then he cut the top off and made it a shorter runner with a sheetmetal top when he upped the build and put it in the montecarlo IIRC.
Old 12-13-2012, 07:57 PM
Yeah, he bought a Marcella intake for his Monet Carlo I believe. He doesn't use the pro-flo anymore, but he used to is what I meant.
Quick Reply: Edelbrock Vic Jr VS. Edelbrock Pro Flo XT
