LS6 intake how much boost
The only seal an LS6 intake can blow out is the intake gaskets, which are pretty much the same for any intake you use. (My edelbrock Pro-flo uses factory GM intake gaskets) So you should not worry blowing them out. People have made well over 1000rwhp on stock intake gaskets. Good luck!
I'd say I'll be 30 or psi
TT-TECH Veteran
I have run 28lbs on an LS6 for quite a while when I was using an F1R on my 346 back up motor NP! GL! Oh and I talked to TPIS about the mod they do to them and while I never pulled the trigger on one especially for the money, they said it would hold as much as the stock one would. I just don't think there would be that much gain if any at all on an FI application to justify trying it etc...
It looks like the newer pieces have some sort bracing to them?
