Huron Speed *Special Edition* Truck Manifold Turbo Kit end of 2012 Special!
Huron Speed 1998-2002 LS1 F-body Truck Manifold Single Turbo Kit
4 Kits are IN STOCK, ready to ship
Special Edition Features & Upgrades:
*ALUMINUM Cold Side Piping
*Pre-Drilled IAT Sensor Hole
*Included Hardware for Alt Relocation, Intercooler Brackets, and Turbo mounting
*Huron Speed T-Shirt
*Huron Speed Windshield Banner
*Huron Speed Small Sticker
End of 2012 Pricing on this special edition kit is $1999.99. You can view and order on our website at:
http://shop.huronspeedproducts.com/F...FBodyTurbo.htm
*Pricing on these 4 in stock Special Edition kit is only good through December 31, 2012*
-This kit is MUCH more complete than your run of the mill Truck Manifold kit. Comes with the complete hot-side, cold-side, all couplers, clamps, brackets, flanges, gaskets, etc as you can see from the picture!
-Hot Side piping is made from 321 Stainless, yes 321, and polished!
-Cold Side piping is made from Aluminum which is a special feature in this special edition kit which saves you 9 lbs from just the material change on the cold side!
Components:
-2.5" crossover with T4 flange and 38mm Wastegate Flange, dump to atmosphere
-3" Downpipe with 3" V-Band flange (3" V-band on exhaust end also for easy to add on more exhaust)
-3" ALUMINUM Cold side piping from turbo to FMIC to Throttle Body (9# weight savings)
-50mm Blow-Off Valve Flange on Cold side piping
-Pre-Drilled hole for IAT sensor on Cold side pipe
-4" core front mount Intercooler
-All exact, specific couplers
-All exact, specific T-Bolt clamps
-All gaskets
-F-body front mount intercoolers brackets
-F-body alternator relocation brackets
-Hardware to mount your Alternator Relocation kit, intercooler brackets, and turbocharger!
-Huron Speed Boost Gauge T-Shirt (Small-3XL)
-Huron Speed Windshield Banner
-Huron Speed Small Sticker
***Please allow 5-10 business days for building of additional components such as added turbochargers is not in stock as well as changing your wastegate flange to the V-Band Style for a 44mm or RG-45 Wastegate.***
Hotside piping made from 321 stainless steel, fully polished.
Coldside piping made from aluminum, can be polished if requested
Requires Turbo, Wastegate, BOV, Oil Lines, Pusher Fans, Misc Hardware, and Truck Manifolds to complete
Kit requires removal of the A/C, Low Oil Sensor, and lowering or removal of front sway bar
Kits include what you see in the picture below!
Components:
-All gaskets
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
__________________
__________________
Ready to ship!
__________________
Get in touch with me and I am sure I can get something along those lines done for you Martin!
__________________
Awesome! There are 2 O2 bungs for your front O2 sensors in it already!
__________________
I have 2 of these left on the shelf, going quick!
__________________
Sounds great Martin!
__________________
__________________
I'm just wondering if it will fit the 93-97 bumber because I'm doing a motor swap. I dont have bumber supports so I'm sure I'll have to fab my own mounts anyways.
Sorry for all the questions but I'm very interested. I'm assuming the truck manifolds do not have O2 bungs. At an extra charge can you weld in some? How much would you charge? I see it has two but I want something for a wideband or two depending on where you recommend the bung should be located.
And what K-member do you recommend. Turbo or non
For a wideband I would put one downstream in the downpipe. You could either put one at the end of the downpipe or in a piece of exhaust you would connect to the end of the downpipe! K member, it was made to fit with a stock k so anything will work, turbo style isn't necessary with this kit let me know of you have any other questions and I am glad to help out!
