408, S488 turbo build feedback
Old 12-14-2012, 10:47 AM
meatheadgn's Avatar
Default 408, S488 turbo build feedback
I am beginning to assemble my 408 and would like some general feedback and pointers as to what to look out for. Here is what I have so far
Iron block Lq4/9 bored .030
Wiseco -15cc pistons
K1 forged crankshaft
Callies forged rods
Comp cam 235/240 .610"/.612" 115+6 thanks to Martin@tick for the cam
L92/LS3 CNC heads with Lunati springs 2.20 intakes
Victor Jr. intake
ARP Main and Head Studs
New ported oil pump
LS9 head gaskets
new S488 BW turbo with 99mm wheel and 1.45 AR
double roller timing set.
Stock coil packs
I will be getting a 90mm TB? but is there something better for this combo?
I am in the process of getting a car to put this in. I am building the engine with my son so he gets to know about LS engines and building in general.
Anything I need to be aware of or that I may need now that I have it all apart?
Old 12-14-2012, 04:58 PM
Blackpanther99's Avatar
Sounds like its gonna be a sick setup, Why wont you use a 102mm Intake manifold with the throttle body?
Old 12-15-2012, 05:34 AM
ittwgn's Avatar
sounds good mate I,m running very similar setup forged iron lq9 408 s400 hp-88 with the 96mm 1.32 ar sheet metal intake 92 mm fast t/b and ls7 style heads !!! currently getting tuned made 800rwhp @14psi 980 rwhp @21psi more to come on aussie mainline dyno thru t400 auto !!! cheers
Old 12-15-2012, 09:47 AM
MillsMotorvation's Avatar
How is that turbo on spool up? Do you run the same cam as this guy? My car will be mostly street.
Old 12-15-2012, 09:56 AM
LS1Tech Sponsor
Slowhawk's Avatar
What tranny?
Old 12-15-2012, 10:23 AM
This is what im hoping for, can you give info on cam, and is car streetable?
Old 12-15-2012, 11:04 AM
meatheadgn's Avatar
I will be running a Powerglide transmission with about a 4000 stall converter. I have a Hughes PG good to about 1500 hp. The car will wiegh under 2400 pounds without driver. I can run any size TB as I have not bought the Edelbrock elbow or have the TB yet. Will a 102 give me enough extra horsepower to justify the cost?
Old 12-15-2012, 11:06 AM
meatheadgn's Avatar
Sounds like a great build from down under. I hope that mine gets those same type of numbers.
Old 12-15-2012, 11:27 AM
Unreal's Avatar
I assume a cable TB? I would go as big as you can swing.
http://texas-speed.com/p-691-ptm-102...ttle-body.aspx
Old 12-15-2012, 07:56 PM
meatheadgn's Avatar
I guess I will be getting a 102mm TB and this looks as good as any. I am getting excited to get the engine together and put it in the car and see how it runs. It should be a good experience for my son to build an engine and then do the swap.
Old 12-15-2012, 08:59 PM
ittwgn's Avatar
hi mate not sure on cam specs it,s a custom one from my mechanic might have to hit him up for specs just to compare to what others are running or being recommended !!!! have not driven it yet with new setup but had an s475 on it before stock heads etc used to get about 5/6psi boost on handbrake with 3000rpm stall so hoping it,s the same as turbine side has not changed !!!!totally streetable driven all the time traffic etc !!! hopefully have a dyno vid in next few days 1000+ ???? to the op at your weight that is going to be insane mine is 4000pds !!!! trying to upload one vid I have but it,s too slow anyway cheers
Old 02-04-2014, 03:51 PM
meatheadgn's Avatar
Default Update
I forgot about having this out there in space and I just found it today. Here are some updates. The car is running and I am putting miles on it last summer and fall. I am looking forward to the spring time so I can finish tuning the Holley HP and get some miles under boost in it. It is actually really nice to drive with the tall tires and 3.73 gears. The PTC converter and Glide seem very streetable.
Thanks to Martin for his cam choice. I am looking forward to getting some boost on it. The 5" exhaust dumped in front of the tire is quite a bit louder than I had anticipated. I have a C6ZO6 with the LG exhaust and it seems tame by the Vega under mild acceleration.
I do wish I was a better and or smarter tuner but I guess that will come. Here are some pics.
The following users liked this post:
JoshuaGrooms83 (06-23-2020)
Quick Reply: 408, S488 turbo build feedback
