Where to place wideband sensor on twin turbo
Old 12-14-2012, 04:40 PM
silversweetZ's Avatar
Default Where to place wideband sensor on twin turbo
I have an Incon twin turbo kit. Where would be the best place to weld a bung for my Uego wideband? I have read you don't want it to far downstream of the exhaust, any help would be appreciated!
Old 12-14-2012, 06:07 PM
65panel5.3's Avatar
i have twins on my 5.3 and put the wideband aproximately 2 ft after the turbo, i put mine on the passenger side turbo(not that it matters a ton) ive heard that running it before the turbo in the hotside pipe will shorten the widebands life due to extreme heat, it seems to be working good for me so far. make sure to mount the wideband as to position the end of the tip at a downward angle, this will help any moisture run out of the sensor when it sits and help stop corrosion, just my 2 cents.
Old 12-14-2012, 08:07 PM
Good info, thanks!
Old 12-14-2012, 11:59 PM
Wicked69's Avatar
I also positioned mine on the passenger side downpipe only. It is also about 2ft past the turbo and just after it starts to bend downwards. Same reason so it won't sit in any condensation. Worked like a charm so far. Only been a year but it is my daily driver.
Old 12-15-2012, 12:59 AM
I didn't even think about the condensation issue. Good point!
Old 12-17-2012, 11:20 PM
65panel5.3's Avatar
hope it worked out for ya
Old 12-18-2012, 07:32 PM
Nebulus's Avatar
Do you guys have separate downpipes/exits for the turbos, or have them meet in a Y? And would two WB's be overkill? I see a lot of people with one and they don't seem to have any issue
Old 12-18-2012, 07:43 PM
tt383lt1's Avatar
i have two aem widebands on my car. and my are duals no y pipe.
Quick Reply: Where to place wideband sensor on twin turbo
