5.3 twin turbo
Old 12-18-2012, 07:05 PM
kpennepacker's Avatar
Default 5.3 twin turbo
Im building an 89 s10 so I am tight on space. My plans were to use truck manifolds flipped and run a single billet precision. After seting the motor and mocking motor mounts it seems everything is in the way to do this...So i flipped the drivers manifold upside down and did the same on the passenger and discovered a perfect mount for twins... So thats the back ground
My motor is a stock 5.3. I put head studs on it and and ls6 cam with patriot gold springs. New rings re-gapped. Meling oil pump. I am running a truck intake with ls1 fbody injectors 80lbs. It will be SD with hp tuners software.
Now will these turbos be good for me or is there a better set.
http://www.ebay.com/itm/Turbonetics-...sories&vxp=mtr
They are the turbonetics hurricane Christina 72mm. I looked through thousands of threads and figured i would ask for an opinion based on my ap. If there is a better set please tell me, i only want to buy once. Im on a budget and cant afford to buy 5 sets for the heck of it.
I've seen tons of threads and hate to beat a dead horse...but I'm confused.
Also is two 45mm wastegates good. With a tial 50mm BOV
Old 12-18-2012, 07:15 PM
burbalanche's Avatar
what are ur plans for it?street or strip or both?what kind of power are looking to make?wastegates and bov should be good.
Old 12-18-2012, 07:25 PM
It would be both. I liked to be in the 600hp range. More would be fine. I'm not sure what the tap out is on the intake and cam combo.
Old 12-18-2012, 07:34 PM
Black98s10's Avatar
1st gens are light as ***, again, how much power do u want? You don't have steering column clearance issues? I know you have a lot more room in the engine bay than me. Good luck bro.
Old 12-18-2012, 07:54 PM
I had to change to different universals. I'll try to get some pics up. Tight though. Lets say I want to shoot for 650hp. Maybe more later as I can beef the motor up.
Old 12-18-2012, 08:00 PM
jridenour31's Avatar
You definitely don't need 72's for that power. 66's will make well over 1000.
Old 12-18-2012, 08:58 PM
Wicked69's Avatar
I would get a set of On3 61 mm's. They would work absolutely awesome in your s10. I run a stock bottom end 5.3 with twin ON3 70's in my 3870lb Chevelle and they work great. Ive run over 25lbs of boost with them on E 85. I would think the 61's would give you more than enough power with your weight and would be sick on the street, ie, instant spool. These are$324 shipped to your door. Can't beat that.
If you go to youtube and type in "Sinister 5.3 twin turbos" You will see tons of videos. Many of them current.
Old 12-18-2012, 09:01 PM
Black98s10's Avatar
I agree, 72mm's are a little overkill. You can even run 62's and make 1000hp and will spool faster.
Old 12-18-2012, 09:06 PM
in that case i got one 66 sittin around would like to free up some cash
Old 12-18-2012, 10:51 PM
Yup, even 62's would make over 1000.
Quick Reply: 5.3 twin turbo
