TT + 390ci..........which turbos....Modular Turbo CBR F2....
Old 12-20-2012, 06:22 PM
LS6427's Avatar
Default TT + 390ci..........which turbos....Modular Turbo CBR F2....
So, I've decided to go Modular Turbo TT kit.....after talking to Robert last night. So......which turbos would be good to go with to make 1,000 RWHP or more (1100-1200 would be nice too)........full time E85 and the Modular turbo A2W intercooler they use and through my 4L80E. Mini-tub and any suspension mods it needs to help it hook. Full weight, full interior.
OR......which mismatched turbos, two different sizes to go with.......
STREET CAR ONLY......STREET CAR ONLY.......roll races ONLY. 40-170mph.
5-6 months is when they can take the car.....I'll be driving it N/A till then with the 390ci........
Old 12-20-2012, 06:33 PM
sschoeffler's Avatar
A twin T76 will be nice. Kinda against the grain and bigger than what most people do. I'm doing a twin T76 build. With a 408, it should be absolutely perfect. Ive done a lot of research on this turbo with compressor maps, engine specs, RPM ranges. It should be a great combo. Very little to 0 lag, 7600 RPM shift redline, turbo is on the verge of surging right after my shiftpoint. Very efficient. Should come alive at around 2200 RPM. Good luck with your build
Old 12-20-2012, 07:00 PM
LS6427's Avatar
I was thinking twin 72's to make over 1,000 RWHP......
NRE has a 402ci LSX iron block TT....uses 2 72MM TURBONETICS TANG. turbos.....makes 1600 FWHP at 14psi on race gas.
http://www.nelsonracingengines.com/p..._402lsx_tt.pdf
CRAZY......
Old 12-20-2012, 07:09 PM
jridenour31's Avatar
Twin 66's should make 1200 to the tire.
Old 12-20-2012, 07:32 PM
qqwqeqwrqwqtq's Avatar
6266's would easily reach your goal and spool very quickly. As for twin 76's, I wouldn't personally use them unless you are aiming for something near 2000hp.
LS6427's Avatar
Originally Posted by Blackpanther99
I would go with twin 76s. I know on a standard deck LSX with twin Precision 76mm turbos make around 1500-1600 at the flywheel. My builder just dynoed a single cab silverado with the setup just mentioned with a billet Wilson intake manifold and the truck pushed 1467RWHP in a Dyno Jet on race gas (which I dont remember). Build still has couple of work to be done to it to be fully complete
Well....twin 76's will fit the kit. I guess I could just turn it up as needed, or till the heads lift.........
Old 12-20-2012, 07:33 PM
LS6427's Avatar
Quick spool is what I want. I'll use whatever will do the trick and not be maxing out the turbos.....
Old 12-20-2012, 07:34 PM
Agreed
Old 12-20-2012, 08:04 PM
Blackpanther99's Avatar
Here are two pics of the build I mentioned
Old 12-20-2012, 09:51 PM
LS6427's Avatar
Cool.....
Are the turbos going to suck air right from the engine compartment...or will you have them sucking air from somewhere else when you're done.
Old 12-20-2012, 11:51 PM
94 slow's Avatar
Anymore pics of the headers/manifolds?
Old 12-21-2012, 10:04 AM
Originally Posted by LS6427
Cool.....
From Two cold air intakes getting air from behind the bumper this isnt my truck btw, its a customers truck, same builder will be working on my Trans Am.
Old 12-21-2012, 10:06 AM
Thats all I have at the moment, I would have to go to the shop to take some pictures.
Old 12-21-2012, 11:36 AM
skinnies's Avatar
This, the 6266 is perfect for the power you want, if you are thinking you might want more in the future, go ahead and order the 6766 now and don't look back.
Old 12-21-2012, 12:14 PM
I agree^ 76s might be too big for what you are looking for.
Old 12-21-2012, 03:52 PM
I personally wouldn't want super fast spool. 1000 rwhp would be scary at 1000 rpm. Full spool at low rpm isn't necessarly a good thing. You will blow the tires off all the time...unintentionally....
Old 12-21-2012, 03:56 PM
Also lets say you full spool at 1000rpm. how many rpm can you go until you start surging the compressor? 5000rpm? These motors love higher rpm ranges.
Old 12-21-2012, 04:23 PM
tt383lt1's Avatar
i have twin 72mm turbo and they spool around 2700rpm and i dont notice any leg even with the 8:1 compression
Old 12-21-2012, 04:54 PM
6266's aren't going to spool at 1000rpm. Even if they did, a boost controller would easily take care of any traction issues and on a build of this level, it's pretty much a necessity. 76's with a proper sized turbine to actually use the compressors, not p or q trims, will take a LONG time to spool on a street 390. They're completely unnecessary for less than 1600 rear wheel.
Old 12-21-2012, 07:00 PM
LS6427's Avatar
edit:..............6766's sound like the winner.....
Quick Reply: TT + 390ci..........which turbos....Modular Turbo CBR F2....
