s475 on untouch ls1, what to expect with 9psi
so just ordered my s475 turbo with 96mm turbine wheel and 1.32 a/r from forced inductions........ thats what they recommended. The car still has stock cam and intake. Like i said long block is untouched. It will be front mounted using manifolds.
60-75 pound injectors
possibly meth injection to be safe..
What should i expected rwhp on 9psi????
Not looking to set any certain number just like to know what to expect.
I have a 6.0 on engine stand for forging future for a backup but wanna run a safe, fun tune on the stock ls till it lets go. Since its already in there lol....
All input is appreciated...
Thanks
Thanks
Its a t56................ and cam is staying stock on this engine. to cheap to put another one in it lol. Ill spend the good money on the future 6.0
im in the dark why i would need springs if i dont plan to turn rpm higher than stock limiter setting. Not doing rod bolts so plan to keep rpm down.....
trust me if you dont do springs , youll be "that guy" making a , "help me figure out why my car wont make any power past 5400 rpm" thread . Dont be that guy.
With that being said, im going to say , 475-480 rwhp
well if im gonna do pushrods and springs i might as well get the cam to lol. That would pick my power up even more..... But i want the weekender to last a while so not wanting to push my luck. And again i could transferr cam over to 6.0 later to so its spend money now or later basically. Any tips for turbo cam??
I wouldn't throw a cam in it just because you're already putting springs and pushrods in it, you only have to pull the valve covers for those. I would, however, put a cam in it because it will help spool and power. Also, it's not going to be any less reliable if you keep the rpm's in check.
