stock truck cam?
Meh,stock cam leaves your setup lacking.I ran mine on my lq4 and I was out of steam by 5200rpm which dosent sound terrible necessarily, but boost builds and the car would pull real hard then run out of steam fast
id contact martin and see what he can set
You up with.there prices are good on cam kits.id go that route but my cars got to pass a tail pipe probe so for now im going to run the ls9 cam
Yeah they will spin to 6k but its pointless.power dropped of pretty hard on mine,i could spin higher but there was no point.
Look for a used cam in the classifieds and then run some Brian Tooley dual valvesprings/keepers/lightweight retainers $200.
The stock cam is a dog. I would upgrade the timing chain as well at the same time. Don't forget to use a new oil pump 0-ring when you put it back together.
