5.3l turbo build
Old 12-27-2012, 02:14 PM
69ChBuLQ4's Avatar
Default 5.3l turbo build
hey guys I was setting up my 5.3l and wondered if there were any suggestions for turbo sizing. I really wanted it to spool quick for street driving and I'm not expecting a ton of hp from it. I hoped for 450 rwhp on a stock cam or an ls1 cause the ls6 cam is looking a little pricey. can one realistically expect much boost at 2000-2500 rpms?
Old 12-27-2012, 03:14 PM
LS1NOVA's Avatar
Well since a $150 cam is out of the budget Ill assume you want a cheap turbo too. Thats fine for what your wanting to do. A Turbonetics TC76 is perfect for your low power, quick spool goals. There is one in the classifieds now and they are cheap. Want even cheaper, the On3 70 or 76 will work too.
If you want to spend a little more with future power goals a little higher, get a Precision 7675 with the .81 ar. It will spool very quickly and you can later switch to a .96 housing and make 850+whp with the same turbo. The others mentioned wont do it.
Old 12-27-2012, 03:23 PM
TheLS1Lover's Avatar
LS6 cams aren't that great for boost to be honest. You WILL NEED valve springs though. The eBay GT45 with its small turbine should meet your goals good.
Old 12-27-2012, 04:54 PM
LS1NOVA's Avatar
The GT45 is the ONE Ebay turbo that actually has a decent sized turbine at 77mm. BUT with instant spool and 450rw as the critieria, not a good choice.
Old 12-27-2012, 06:17 PM
You're correct, my mistake, I meant the compressor side.
Old 12-28-2012, 09:32 AM
69ChBuLQ4's Avatar
thanks for the advice, are those turbos mentioned .81 ar or smaller?
i was thinking the ls1 or ls6 cam for the budget mindedness of the build but if its not much of a gain over stock 5.3l then i guess not.... the stock cam is such loowww lift though.
Old 12-28-2012, 09:36 AM
69ChBuLQ4's Avatar
was thinking about a cam and spring set like this too. I know its not the perfect turbo cam but the intake and exhaust duration are pretty close:
http://www.ebay.com/itm/Used-LS1-Com...90836012439%26
i was also wondering when you said i need valvesprings you probably meant dual springs? and i know ppl say some things about comp duals that they break and such.
Old 12-28-2012, 09:38 AM
69ChBuLQ4's Avatar
actually here is a healthier cam with a set of duals and pushrods!
http://www.ebay.com/itm/LS1-Comp-Cam...2ec379&vxp=mtr
Old 12-28-2012, 10:19 AM
71 chevy's Avatar
for the power you are looking for, keep the stock cam. 6psi and stock cam would get you there.
Old 12-28-2012, 11:14 AM
69ChBuLQ4's Avatar
alright if I keep the stock cam would I need a valvespring upgrade still for valve float?
Old 12-28-2012, 04:23 PM
Yes you will, the Brain Tooley Racing .660 Springs are only $220 at Speed Inc.
Quick Reply: 5.3l turbo build
