the Mighty LS6 cam.post your combos
Old 12-28-2012, 10:22 AM
71 chevy's Avatar
Default the Mighty LS6 cam.post your combos
I know several guys are putting up some damn good numbers with these cams.
please post your setups, including track times, videos, amount of boost, etc.
Old 12-28-2012, 11:00 AM
js2fst's Avatar
I was not impressed with it but we only had 10 psi
Old 12-28-2012, 11:01 AM
oldschoolmuscle's Avatar
im goin to do a ls6 in my 5.3. id be intersted to see what people are making.
Old 12-28-2012, 11:20 AM
30th t/a's Avatar
Forged 347, LS6 cam, stock 317 heads with 79CC chambers, LS6 intake, ported stock TB, 8.8:1cr, 4L80e, Yank 3000, twin 57mm turbos 603/600 on 14psi. 93 octane only.
Old 12-28-2012, 11:21 AM
HioSSilver's Avatar
I'm n/a...but #'s in the sig
Old 12-28-2012, 11:25 AM
71 chevy's Avatar
I would still like to know what numbers it put down ,and what it ran at the track
11.05 NA? with the LS6 cam?
Old 12-28-2012, 11:58 AM
HioSSilver's Avatar
Yep....crate ls6 actually. There has been quicker ls6's. My 10bolt busts a axle eveytime I really get after the launch. I do have the best mph of the ones i know of, but it could come down a bit with a better launch.
Old 12-28-2012, 01:55 PM
Rpayne41985's Avatar
Damn that's some big mph
Old 12-28-2012, 01:58 PM
LS1Tech Sponsor
hellbents10's Avatar
Here is a few.
From highest to lowest
S374 83mm turbine, 6sp manual GTO, 9.9@142
S368 83mm turbine, 4l80e 35" tires and floating 14 bolt
TC76 68mm turbine, Silverado 80e, 22" wheels
Old 12-28-2012, 02:06 PM
SilverSS's Avatar
01 LS6 Cam
370 9:1 F1A 17psi
820rwhp
Street car only.
Old 12-28-2012, 02:21 PM
got-a-ls1's Avatar
i ran 109mph in the 1/8th mile at 3800+ pounds. should be around 700 rwhp. and that 109mph run was only using about 580 feet , ran the rest of the 1/8th mile out on the rev limiter (well before the first timing box at the end). et is only 6.92... hard to hook up small tires and power at this track.
im building a forged 5.3 and plan to use the ls6 cam in that as well shooting for 800 rwhp and 115mph in the 1/8th mile
Old 12-28-2012, 02:41 PM
Fb0dy0nly's Avatar
Originally Posted by 30th t/a
Forged 347, LS6 cam, 317 heads with 79CC chambers, LS6 intake, ported TB, 8.8:1cr, 4L80e, Yank 3000, twin 57mm turbos 603/600 on 14psi. 93 octane only.
nice setup, any plans to move up to 67's? what does it run in the quarter? any times?
anyone have an ls6 or similar cam for sale?
sorry op
been lookin for years and havent ran across one yet for reasonable price or I'm two minutes too late... pm me if so
Old 12-28-2012, 03:06 PM
Fahrenschnell's Avatar
Forged 6.0....317 heads....8.5 cr....LS6 Cam and intake.....S480 Turbo
780 hp at 14 lbs....
Old 12-28-2012, 04:39 PM
1BADAZZSS's Avatar
Im looking to do a ls6 cam in my new 6l, s488. Car ran good with a tsp v2 cam thats more of a na cam. Lq9 and ported 317s i maxxed my twin pump setup e85,on 14#. Never dyno'd but from the cars i ran on the street i felt as tho 800ish to the wheelz.
Old 12-28-2012, 06:16 PM
js2fst's Avatar
04 cam stock long z06 valve springs (could have floated didn't feel it) meth 85 mm intake and tb rails all pp 42lbs injectors exhaust lt 11 psi 4l80e 9 in 547 rwhp
Old 12-28-2012, 10:06 PM
oneoverwrx's Avatar
Stock 4.8 with 243s and ls6 cam eBay gt45 9.18@146 2900lbs with driver. 5.88@119 in the 1/8th, converter was killing us.
Old 12-29-2012, 01:11 PM
atomic 6's Avatar
We have had these three different cars with the two different styles of Z06(LS6) cams make great power.
The Turbo Fairmont ----01 Z06 cam went 9.49 @ 3150lbs LM7 5.3
Mike's mustang --------01 Z06 cam went 8.98 @ 3400lbs LQ4 6.0
My Twinturbo wagon --02 Z06 cam went 10.0 @ 3850lbs (with old 6.0 LQ4)
Switched to an L33 in the Wagon, then made 800.8 RWHP at 18 lbs boost. Reusing the Z06 cam from the previous 6.0 build.
Could we have a better cam in there??? Probably. But we push these engines till they break,and so there is a good chance the cam could get really screwed up in the process. And has before. If I can get a cam like this cheap, and it works, why not.
Just,So I can run the same power at less boost????
I don't care how high the boost is, I only care about the power we are making. I am from the "old school" buick TR world, and the fun isn't starting with those till above 30 lbs, high boost numbers don't bother me, and with many of the turbos we run, the compressor maps indicate high boost is needed to get the output from those without them overspeeding.
Jim had a cam speced by Patrick G in his G8,and it definately sounded better than the LS6 cams we have been using,and it worked well. Does Pat G still do that around here?
That is one thing about the LS6 cam, it doesn't sound that good at idle, and that really helped our "sleeper" fairmont. But doesn't fit the look of my Wagon, or Mikes mustang. Small trade off for me.
What sucks is these LS6 cams use to be easy to find, but are now much harder. And I am not sold on the LS9 cam yet. All tho the gen4 pullout cams are more atractive to me, now with the Microsquirt being able to run an LS engine strickly off the crankshaft wheel(no cam input needed)
I'm sure everyone has seen the videos of the Fairmont,Mike's 8 sec run, and the 800 hp dyno vid of the NovaWagon, so I won't post them here.
Old 12-29-2012, 03:59 PM
71 chevy's Avatar
amazing. how much boost?
Old 12-29-2012, 06:59 PM
71 chevy's Avatar
please post those vids !
im not sold on the ls9 cam either but time will tell.
Old 12-30-2012, 12:37 AM
LosLs1's's Avatar
My camaro made 641rwtq and 629rwhp on 12#'s Has a lq4 stock heads and 03 ls6 cam, spraying meth, turbo is a turbonetics T76 with the 68mm turbine wheel. We tried 14#'s but didn't change much.
Quick Reply: the Mighty LS6 cam.post your combos
