Opinons on wastegate placement.
Old 12-30-2012, 07:45 PM
357i's Avatar
Default Opinons on wastegate placement.
Time to mount the wastegate on my home made turbo setup. I bought a PTE 46mm wastegate and would like some opinions on where to mount it. I have an idea, but would love to hear what others have to say. I know there are a pile of turbo systems out there that have the wastegate mounted right into the side of the collector, which is easy, but I am hoping to hold singe digit boost(8-9psi) and I am afraid a wastegate mounted like that will not have the control I want.
Here are a couple pics of what I've got.
Old 12-30-2012, 07:57 PM
Wicked69's Avatar
I thought it needed to have the wastegate PRIOR to the exhaust flange. Yours is after the exhaust flange. Not sure if that would work. I am curious also.
Old 12-30-2012, 08:21 PM
allout06's Avatar
?? this
Old 12-30-2012, 08:23 PM
Twin turbo c5's Avatar
I've always built my kits with the wg as close to the turbo as possiable . I've haven't had any problems holding 6 psi on any of my junk yard kits . You'll have alot of different opinions that's just what's works for me .
Old 12-30-2012, 09:26 PM
jridenour31's Avatar
Originally Posted by allout06
?? this
This is what I would do if there's room, hard to tell from the pics. You could also make an outlet on each on the bends before the merge and y them together so the gate is getting priority from both banks.
Old 12-30-2012, 09:55 PM
Ping King's Avatar
You could always just vent one side. Ive done it before. While not optimal it still works.
Old 12-31-2012, 06:29 AM
LS1NOVA's Avatar
Id put two elbows off the merge and mount it on top.
Old 12-31-2012, 10:46 AM
Tjabo's Avatar
That could provide nice WG priority if there is room to do it.
Quick Reply: Opinons on wastegate placement.
