F-body Procharger w/Iron Block 6.0L - ????????
So there are a lot of 370's, 390's, and 408's out there with blowers.
What are guys doing on F-body's about the missing bolt hole on the iron blocks for the alternator mounting location?
I found these two threads but there has got to be more?
https://ls1tech.com/forums/forced-in...ore-boost.html
https://ls1tech.com/forums/forced-in...t-bracket.html
I don't want to just run with out it.
That works for one of the mounting holes, what about the other missing one?
The iron block is missing two mounting holes, one just needs to be drilled and tapped as you stated, the other is simply not there. See photos below
Aluminum block
Iron Block
Aluminum block
Iron Block
Here's how I did mine. I also drilled and tapped my block. It drills and taps really easy, blocks must be a soft metal.
Here's the link to the old set up I did..
https://ls1tech.com/forums/forced-in...t-up-pics.html
Since the j-bracket bolts to the alternator bracket, techincally there are only two bolts holding the blower on. Correct?
Am I missing something?
Just the two holes are more than enough for the alternator if you use the brackets on the back of the alternator to hold it in place. I have done it for my last two LS swaps and havent had a single problem
I'm not so concerned with the weight, I am concerned about only two bolts holding the blower and the stresses it will put on those long bolts. These cars are already cursed with a bracket that flexes a bunch, then if you take away one of the three mounting locations, it will be worse.
LS1Tech Sponsor
I have never run into a problem with the one hole in the bracket not being used. We ran my iron block with it this way, both with the stock J bracket at 18 psi and then when we came out with the cog bracket, back at the old shop. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
If I am available when mine is done, I will get a video and some pics of how its done, for others too see. You would expect a really detailed writeup on it somewhere but its just not there but I dont think its really that hard to begin with. mess it up though, and i bet your in deep do do
https://ls1tech.com/forums/forced-in...e-boost-4.html
Post #72 Look at that see if that will make you sleep better at night...
60, 60l, alternator, block, bracket, build, camaro, carbureted, charger, d1sc, holes, ls1, mounting, pro, procharged, procharger
