835whp new comp ct5 88mm
Just took the car off the rollers at speed inc. I left the setup exactly the same except swapped the 80/79 turbo for a ct5/ct43 hybrid that uses an 88mm comp wheel and 94/88mm turbine. This is a t4 turbo with a 1.10 ar housing and 4 inch dp.
At 14psi it made about 700whp. At 19.5 it made 835whp through a locked auto and 9 inch.
What i was really happy about was that it made power past 6k rpm. Before it was done by 5200rpm.
Graph is coming soon. Thanks to Jim at speed inc for the great tune. Also,its been a long road with comp turbo and I but in the end I am happy with the turbo.
Its a 9.5:1 comp 370,stock ported 241 heads,232/236 .600 115lsa cam. Stock ls6 intake and tb. Flt level 7 4l65e with a 3disc vig 3600, Moser 9inch with 325 gears.
I believe i was sold the wrong turbo twice for my setup. In the end i just had to spec my own. They took care of me as far as cost goes. Just frustrating getting straight answers. But they sent me this one at no extra charge and kept working with me. So im happy with that.
Im glad to hear they worked with you and got you what you wanted.
Also, just curious, did you get the ET in your sig with the setup thats listed?
