Victor JR setup??
Old 01-10-2013, 05:42 AM
FasTimeSS's Avatar
Default Victor JR setup??
I am starting to buy the parts to complete my turbo build. I need to know what elbow and throttle body I should run with the victor jr intake manifold. I need some intake opinions please. Should I even run a Vic Jr.?? Is there better intake setups to run for this? Also the build consist of 408"ci 9:1 compression ratio, stock 317 heads, KYTP hotside and S488 turbocharger. I haven't pick up any other parts yet. I also do not want to cut the cowl all up if I do not have to. Thanks for the help in advance guys.
Old 01-10-2013, 06:13 AM
ws602's Avatar
are you willing to notch the cowl?
Old 01-10-2013, 06:38 AM
pwrtrip75's Avatar
You dont need to notch the cowl with this one. I have one on mine.
Edelbrock Throttle Body Intake Elbows 3847
Old 01-10-2013, 06:53 AM
dschmittie1's Avatar
I am running an Aarons elbow on mine with a stock Throttle body. It has been 8.79 so far.
Old 01-10-2013, 07:06 AM
FasTimeSS's Avatar
Where is the best price on the aarons. I like the look of that over the edelbrock. The edelbrock is about 200 bucks cheaper from what I find online.
Does anyone one know if the edelbrock flows as well as the aarons or vis-versa?
Thanks for the help.
Old 01-10-2013, 07:08 AM
FasTimeSS's Avatar
I will if its gonna flow alot better!! I don't want to though because then I will have to notch the hood also.
Old 01-10-2013, 09:33 AM
SKINNY69's Avatar
What elbow are you guys running that have a sunoco style hood and don't need to worry about clearance? I don't mind notching the cowl a little but I don't want to hack the **** out of it either.
Old 01-10-2013, 02:27 PM
Taubr Unit's Avatar
I bought my 6061 elbow directly from Aaron's website. Only thing I was told about the Vic jr/elbow combo is you want the airflow downward as poss before the manifold so I have a 2" spacer on mine.
Old 01-10-2013, 02:29 PM
Stangkilr's Avatar
Run a stock intake
Old 01-10-2013, 04:41 PM
78buturbo's Avatar
I'm assuming your not using the super victor intake because of Clearance, but I would think with your combo it would be a good choice at least from my research and talking to other guys.
Old 01-10-2013, 07:12 PM
GrimReaper's Avatar
I like this, looks good.
I was talking with a cylinder head guy this last week. His only complaint was the difference in flow between the middle 2 runners and the outter 2. 40cfm difference. This is just what i have been told, i do not have facts to back it up.
I am searching for a budget minded intake option for my build as well right now. Vic jr seems to be the best option for affordability and fit. I hear the Holley hi ram is better but the cowl has to be notched to fit.
Old 01-10-2013, 08:37 PM
MillsMotorvation's Avatar
Im in the process of adding a vic jr, on a new setup! Good info here. Had to drill my Vic intake to take the injector, but it worked fine!
Attached Thumbnails Victor JR setup??-new-pics-014.jpg   Victor JR setup??-new-pics-006.jpg
Old 01-11-2013, 05:43 PM
waterbug1999's Avatar
VR Jr and Aarons as well..
Old 01-11-2013, 08:17 PM
allout06's Avatar
i heard the vic jr isnt a good idea to run because of flow to each cylinder is different or something? Any info on this? Im also looking at intake options... I was gonna run the LS6, but wouldnt mind having something like this more so for the look.
Old 01-11-2013, 08:46 PM
I8UR4RD's Avatar
^ powdercoated pro flow FTW
Old 01-11-2013, 08:48 PM
dmaxvaz's Avatar
Anybody know if the edelbrock pro flow it is any good?
Old 01-11-2013, 10:50 PM
allout06's Avatar
Gotta look into them
Old 01-12-2013, 01:39 AM
Pwebbz28's Avatar
Dumbest **** I've ever heard. The main issue with Vic jr is the available elbows suck when you try to stuff them under a stock hood
Old 01-12-2013, 06:20 AM
87silverbullet's Avatar
One of the guys on here has made over 1k rwhp with an edelbrock pro flow but as for clearance you will cut the **** out of an f body cowl. The guy I'm talking about has a nova so that doesn't matter to him.
Old 01-12-2013, 09:39 AM
GrimReaper's Avatar
So whats the fastest FI 1/4 mile time with the Vic Jr?
Quick Reply: Victor JR setup??
