Hollow ls3 and inconel ly6 valves in an lsa head?
Old 01-12-2013, 08:44 PM
turbotuner20v's Avatar
Default Hollow ls3 and inconel ly6 valves in an lsa head?
Just curious what people thought of this ls3/ly6 combo for forced induction. I'll be running an f1a at 20psi on a 6L and need valves for the bare lsa heads I bought.
Old 01-12-2013, 09:53 PM
Jakson's Avatar
I'm running these valves in my L92s working great so far with a few dozen dyno pulls to 7500@ 20psi.
Old 01-12-2013, 10:15 PM
98blackbirdta's Avatar
those are the valves im going to run aswell.
Old 01-13-2013, 10:53 AM
Does the hollow stem and 2 piece inconel design cause any concerns about durability?
Old 01-13-2013, 01:48 PM
Is the other option people use ferrea f1892p and f2010p?
Looks like another $225 to upgrade to ferrea... Worth it?
Anybody have the weights of these 4 different valves?
Old 01-14-2013, 06:11 AM
baggins's Avatar
What's the price for them?
Old 01-14-2013, 09:49 AM
I think the LS3/LY6 valves were $377 and the Ferrea hollow intake/super alloy was like $600
Old 01-14-2013, 02:22 PM
Here are the weights:
Ferrea f2010p hollow intake = 108.6 grams
Ferrea f1892p super alloy = 98.6 grams
Stock LS3 intake = 89 grams
Stock LY6 exhaust = ? grams
Stock L92 intake = 109 grams
Stock L92 exhaust = 89
Anyone know the weight of the LY6 exhaust valve?
Thoughts on the weight difference between the LS3 and Ferrea intake valves?
Should I post in internal engine?
Old 01-14-2013, 07:03 PM
Jakson's Avatar
When I weighed my valves I got 89g for the LS3 intake, and 91g for the LY6 exhaust.
Old 01-14-2013, 07:34 PM
Cool, thanks.
I think I'm just going to get the ferreas. I'm only revving to 7k on a fairly mild blower cam, so the weight won't make as much difference as the added strength will.
Old 01-14-2013, 11:29 PM
eb02z06's Avatar
Originally Posted by turbotuner20v
Cool, thanks.
The lobes on the cam will allow you to use any of the above valves.
I'm in the same boat as you right now-I was going to use some Hollow Stem GM intakes but now I'm a bit scared since there a 3 piece.
I heard the REV 2.165 intakes are as light as the Ferrea Hollow Stems-however I cannot find any info online.
As far as exhaust goes-I'm just going to use the stock exhaust valves that come on the LSA heads, no need for inconel with a street blower.
Old 01-14-2013, 11:40 PM
Good to know, I was thinking about emailing you to see how those valves would get along with the cam and bt springs
Old 01-15-2013, 06:48 AM
Realcanuk's Avatar
I just changed my valves to Ferrea and used super alloys on the exhaust. I broke a valve spring (mechanical over reved the engine) and the valve touched a piston. I considered going to LS3 valves but then started thinking if I had those the valve probably would have broken and cost the whole motor. The REV valve that was in there just bent a little and did no other damage.
Old 01-15-2013, 12:41 PM
eb02z06's Avatar
All the lobes I uses are rpm and boost friendly-and easy on springs too.
I've had to learn the hard way!
Old 01-15-2013, 02:26 PM
pulled the trigger on this combo
got them for $537 shipped, which was hard to turn down. Best price I could find on the stock valves was $377 shipped.
Old 01-15-2013, 08:20 PM
gjohnsonws6's Avatar
Lingenfelter has the ly6 exhausts
Quick Reply: Hollow ls3 and inconel ly6 valves in an lsa head?
