WS6 S475 official build thread.......
Old 03-21-2013, 07:43 AM
  #81
mrstepheneades's Avatar
Originally Posted by Camaro9969
Oh ya your using the fans as pushers damn that will be a lot of work extending all those wires.
the fan wires will not be that big a deal..... its the twenty other wires lol. I wanna run entire wire cluster on bottom in front of radiator supports and back up passenger side.. Hide it best i can..
Old 03-21-2013, 07:53 AM
  #82
Camaro9969's Avatar
Ya that's what i was thinking of those wires will be a pain but id say under the radiator support and above the air dam would be a good idea? it would hide everything completely.
Old 03-21-2013, 08:16 AM
  #83
pnykillerz28ls1's Avatar
i ran my wires under the rad support and behind the air dam and didnt have to extend many of the wires but that also might be because i have hids and the balast for them gave me more to play with im not sure about the rest of the wires that go up the fender cause my motor isnt in but it looks like i should be able to make it work with out extending to may of the wires.
i was also wondering with the pumps did you have to buy 2 hot wire kits or were you just using the one to power both pumps
Old 03-21-2013, 08:39 AM
  #84
yeah thats what i was planning on doing... i dred it lol
Old 03-21-2013, 08:41 AM
  #85
i just purchased one hotwire kit for the two pump setup.
Camaro9969 may jump in on that since his is running and he has same stuff i bought
Old 03-23-2013, 05:09 AM
  #86
Progress on polishing... Its a timely process but this is what ive accomplished so far on the downpipe... Still have some work to do on it..
Old 03-23-2013, 06:37 AM
  #87
MUSTANGBRKR02's Avatar
Why are you polishing it? I would wrap the entire hotside at least once.
Old 03-23-2013, 08:50 AM
  #88
Camaro9969's Avatar
Ya it looks great but you will want to wrap it since its close to your cold piping.
Old 03-23-2013, 09:12 AM
  #89
cause it looks good lol.....
Old 03-23-2013, 09:14 AM
  #90
ill see how it does.... i like the look of polish and would sacrifice a few hp for the look lol..... just spray more meth lol
Old 03-23-2013, 10:58 AM
  #91
Camaro9969's Avatar
I like the polished look just see how hot it gets and go from there. You will probably have to wrap it if your going to be driving it on the street often. I see two things on that dp a exhaust temp and what's that other flange for?
Old 03-23-2013, 12:23 PM
  #92
alex5.3t's Avatar
I like the polished look just see how hot it gets and go from there. You will probably have to wrap it if your going to be driving it on the street often. I see two things on that dp a exhaust temp and what's that other flange for? It almost looks like a bov flange
Probably for the waste gate to tie back into the exhaust, with a v-band.
Old 03-23-2013, 01:24 PM
  #93
Camaro9969's Avatar
Oh ya forgot about that. I didn't see his wg placement
Old 03-23-2013, 08:14 PM
  #94
Its where the wastegate plumbs back in. Instead of dumping on ground it goes out the dp. The other small one is for wideband for tuning... the side the flange is on faces in and dp exited out passenger side front bumper. So your looking at it flipped around and backward. The smooth pic above where you see no flanges is what you see when opening hood.
Old 03-26-2013, 07:24 AM
  #95
Here is a picture showing where the wastegate ties back into the downpipe....Downpipe has been removed and left the wastegate in place..
Here are a few more pictures showing the upper radiator pipe in place without the downpipe or radiator in there where you can see pipe routing better...
Old 03-30-2013, 05:00 AM
  #96
Just got my Twin Walbro 340s in with hotwire kit
Old 03-30-2013, 06:19 AM
  #97
Camaro9969's Avatar
Sweet! Its a pretty straight forward install too. Just the fuel pump bucket is the only thing you need to take your time with
Old 03-30-2013, 06:58 AM
  #98
was thinking of doing it from the trunk... You know make an access door to fuel pumps like people do but was unsure if i could get to the wiring stuff from the top or at least feed the wires down thru to where i can get from underneath... cause i know they plug in underneath in front of tank.. What you think???
Old 03-30-2013, 08:19 AM
  #99
Camaro9969's Avatar
Ya go from the top cut an access panel and all the wiring is right there much easier than dropping the tank. There's a bunch of threads but if you want a picture of it ill take one for you
Old 03-30-2013, 08:57 AM
  #100
ill probably cut a much bigger hole than needed cause im all about ease of doing things lol.... yeah take me a pic if its not to much trouble....
Thanks
Oh and on all those wires i may not have to lengthen any of them at my radiator.. Just loosen up a few spots where harness is connected to frame and should be able to have enough play room then..
Quick Reply: WS6 S475 official build thread.......
