WS6 S475 official build thread.......
Old 01-14-2013, 11:16 AM
mrstepheneades's Avatar
Default WS6 S475 official build thread................
It has begun. Just getting started on my build. Figured i would start with the pictures of progress.
This build may take several more months but will update as i get more done...
Let me know what you think...
Its a stock ls1 6speed car
s475 borg warner from forced inductions with 1.32a/r and 96mm turbine
More parts to come but this is where im at so far....
Old 01-14-2013, 11:51 AM
topgun542's Avatar
nice dude! ill be going wih a very similar borg. Looking forward to see this thing go!
Old 01-14-2013, 12:03 PM
F110Mech's Avatar
I think you might have some issues keeping it spooled with the 6spd. Other than that, nice welds!
Old 01-14-2013, 12:22 PM
My friend David doing all fabbing. He does excellent work. I bought the turbo big enough to move up to a forged 370 when factory ls lets go. I know it will be little laggy.
Old 01-14-2013, 12:45 PM
Blackpanther99's Avatar
It wont spool as you want to but it will make good power
Old 01-14-2013, 12:53 PM
guy at forced inductons said it would spool about 3500 to 4000 somewhere in there...
Old 01-14-2013, 01:04 PM
Old 01-14-2013, 01:08 PM
all piping is stainless in this build................
Old 01-14-2013, 01:33 PM
TheLS1Lover's Avatar
Get the right cam and it should spool just fine, that and the tune. Fab work looks good, good luck with it.
Old 01-14-2013, 01:45 PM
Thanks....... we will see how and where it goes. My budget will limit the speed of the build lol....
Old 01-15-2013, 07:31 AM
drivers side hot pipe fitted up last night.............
Old 01-16-2013, 07:36 AM
got the paasenger side fitted last night and started on the merge............
still a lot of work to do on the merge but its getting there
welded the flanges all the way
Old 01-16-2013, 07:40 AM
club_xcursion's Avatar
very nice welds. good luck with it.
Old 01-16-2013, 07:46 AM
Thanks
Old 01-22-2013, 07:35 AM
merge pipe finished fabbing last night
Old 01-23-2013, 07:18 AM
radiator mocked up........ stock fans flipped around for pushers
looks much cleaner without the fans mashed against turbo i think
Old 01-23-2013, 08:56 AM
Sales@Tick's Avatar
This x2! Really needs correct cam timing and mainly overlap for a 6 speed turbo car.
Old 01-23-2013, 09:06 AM
what cam would you suggest?
Old 01-23-2013, 01:18 PM
Sales@Tick's Avatar
First I didn't realize you were in Statesville!!! Nice to see a fellow NC resident!
For your unique situation I feel there is no off the shelf cam that will fit your build, so a custom cam would be in order. What I would need first is some information in regards to what parts you'll be utilizing in your application such as the cylinder heads, valve size, intake/exhaust port size, compression, intake manifold, rear gear, weight of the car and there are more that I have saved in my cam spec sheet if you want to fill it out I can give you a much better idea.
Old 01-23-2013, 02:05 PM
lol what about all stock and more stock untouched long block haha.... only gonna push 9 psi...... this is a budget build.....Just wanna have some fun till one day i get my 370 built. It will have all the goodies.... You think i would really benefit that much to be worth the cost of cam/springs/pushrods with boost on factory untouch ls1???
stock 3.42 gears also......
i mean i know stock internals not gonna hold forever so not gonna wanna put a grand in a cam upgrade for 40 rwhp
Quick Reply: WS6 S475 official build thread.......
