Good place to start on tune.
Stock bottom end 5.3
Rings opened up
ARP rod bolts
Mid 22x cam
Stock heads
70mm turbo
Dual intank pumps
80lb injectors
Will be running e85 with no inter cooler. Thinking of starting with a 9 temp plug. Will be slowly turning the boost up to 14+. Will be 3 bar SD via hp tuners.
Thoughts?
Rings opened up
ARP rod bolts
Mid 22x cam
Stock heads
70mm turbo
Dual intank pumps
80lb injectors
Thoughts?
