View Poll Results: best cubes for 6ltr iron block to suit turbo
stock crank forged 370
15
41.67%
AES 390
11
30.56%
callies based 402/408
10
27.78%
Voters: 36. You may not vote on this poll
best cubes for a street strip lq9 iron block with big single turbo
Old 01-20-2013, 08:02 AM
PROLSXSS's Avatar
Default best cubes for a street strip lq9 iron block with big single turbo
Ok so I'm building another toy I have a complete lq9 6ltr engine and im going to build it to suit a comp ct6x 91/100 billet turbo I have and some parts iv got left over from my race car build.. now my question is what cubes should I go with as far as reliability etc and overall power
The options I believe are
-370
-390
-402/408 (depending on bore condition)
any input would be great also my heads will be mild ported LS3's with a Holley hi ram intake and will be backed by a 4l80e for street duties
Old 01-20-2013, 06:55 PM
PROLSXSS's Avatar
Anyone? I just thought I'd see people's input those one will be a budget combo as I don't want to build another 410 LSX
Old 01-21-2013, 08:05 PM
PROLSXSS's Avatar
bump it up
Old 01-21-2013, 09:29 PM
LS6427's Avatar
AES 390 iron block is my choice. The cubes don't make a big difference, the turbo does the work. I chose iron block AES 390ci. 80 pounds or so is meaningless in extra front end weight, unless you're doing some kind a serious competition and every 10th of a second counts.......
You want much better strength and reliablilty....go iron 390ci. Its right in the middle of your 3 choices for cubes and it'll be a strong little bastard waiting for 20psi.
Old 01-21-2013, 11:52 PM
PROLSXSS's Avatar
Thanks dude was thinking the same only iv seen cranks are hard to get for the 390 or has AES sorted this?
Old 01-22-2013, 10:23 AM
dschmittie1's Avatar
What are the exact specs on the Turbo. Could play a role on cubic inch choice
Old 01-22-2013, 10:57 AM
LS6427's Avatar
The only thing that was holding up AES from building my 390ci a few months ago was the 3.825" crank.
So I picked up the phone and called callies directly and asked if they had one on the shelf that needs to be finished. They said yes.....and that they would ship it out in 6-7 days. I paid them $660.00 + $45.00 to drop ship it to AES. It was shipped in 6 days. Then AES had my engine out the door to me in another 6 days.
Screw waiting for engines to be built for months...get things done yourself.
Old 01-22-2013, 07:29 PM
PROLSXSS's Avatar
the turbo is a comp ct6 tripple ceramic billet 91mm turbo with a gt55 turbine and a 1.39AR
Old 01-22-2013, 07:31 PM
PROLSXSS's Avatar
im in aus so i might call them tonight and have a talk doea anyone but aes do the pistons to suit?
Old 01-22-2013, 07:33 PM
PROLSXSS's Avatar
actual part number 691100-1X (TRIPLEX CERAMIC Bearings)
Old 01-22-2013, 07:45 PM
703 CAMAROSS's Avatar
Another for 390, shorter stroke is more reliable.
Old 01-22-2013, 08:03 PM
PROLSXSS's Avatar
so far its looking like 370 or 390 no love for the 408 combo and for the extra 20 cubes and the added waiting time i might just go 370 im going to keep waiting to see others opinions as im not in a rush to start it
Old 01-22-2013, 09:02 PM
milkey57's Avatar
390 here too, throw on a pt91 1k hp all day long. These motors are beasts!!
Old 01-23-2013, 02:08 PM
LS6427's Avatar
Diamond makes their pistons. You can call them and get the same exact pistons they use in their 390's.
I went with flat top pistons because I'll be using E85 and 10.3:1 cr with my 18-20psi.
But I think they use a -15cc dish piston for their lower compression 390 boost built engines.
Old 01-23-2013, 03:22 PM
Beanslsxnova's Avatar
I would go for the 370 just for simplicity, and no wait time for parts. Diamond pistons and good set of h beams can be had for $1500. set of main studs and to the machine shop you go. But then again that's the prespective of a poor person lol. What are your plans for the car? street car/race car or one or the other?
Old 01-23-2013, 10:57 PM
PROLSXSS's Avatar
Yeah it's gonna be 80% street 20% dyno/drags money is not a drama for me I just want it to work
Old 01-25-2013, 06:51 PM
PROLSXSS's Avatar
Bump it up
Old 01-25-2013, 07:09 PM
67Firebird455's Avatar
Yeah, I still say 370 for the simplicity of the whole thing. You can make big power on a stock crank with a good piston/rod combo. Save the money for the crank and put it toward a nice set of LSA's or thick deck aftermarkets.
Old 01-25-2013, 07:29 PM
LS6427's Avatar
True. Stock cranks are definitely badass.......but for $660.00 I see no reason why anyone would not go for the Callie's 3.825" forged crank, and have more strength and reliability, less weight and be safe for well over 1,000 RWHP. Plus more cubes for faster spool up. I mean a complete turbo set up....engine, turbo kit and everything is gonna be over $10,000.......$660.00 seems logical to spend on the heart of the engine. But that's just me.
Old 01-25-2013, 07:38 PM
PROLSXSS's Avatar
Cranks are a bit more than that over here I can't even get anything near that from any of my suppliers iv got a set of hand ported ls3 heads I was going to throw on with some ls9 gaskets and ARP studs I have sitting around so I already have heads sorted but Im still open for suggestions on cubes it's looking like 370 or 390 so far
Quick Reply: best cubes for a street strip lq9 iron block with big single turbo
