Dual external Wally 255hp on E85 base fuel pressure
Old 01-28-2013, 10:28 PM
ronnieforrester's Avatar
Default Dual external Wally 255hp on E85 base fuel pressure
I "ran out of injector" (90% DC) making about 560whp with a bad converter in a TH400 at 15psi in my 4.8 TC78 fox fox body.
Im sure the converter was costing me some whp- it has been restalled since the dyno.
I was only on a 2bar map sensor and about 48psi base fuel pressure.
I want to toss in a 3 bar map and add 5-7 psi of boost and hopefully make about 650whp on the little TC78.
the pumps are y blocked at the rear of the car with -8 supply and return.
what would you jack the base FP too ?
I know the Wally's don't like higher fuel pressures.
Old 01-29-2013, 12:48 AM
Moderator
denmah's Avatar
eh, skinnies is using a pretty high base pressure with multiple walbro's bump the pressure 20psi and see what it gets you, wont know till you try.
i say just buy big injectors, you wanna make big power and your out of injector at 560whp already, **** man just go get some 80s or something, whats in the car now?
Old 01-29-2013, 06:58 AM
Damn. Forgot to mention this was on 80lb injectors.
Yea I saw an older thread where skinnies was using triple walbros.
Old 01-29-2013, 07:15 AM
a4ls2goat's Avatar
Crank the fuel pressure up.
Old 01-29-2013, 07:16 AM
skinnies's Avatar
80's are good to right at 800rwhp(I tell people 750rwhp is where I'd stop tho to be safe) with 2 walbro pumps. We run ~95lb in boost at 850+ rwhp and 80lb injectors and 3 pumps.
Old 01-29-2013, 07:55 AM
I unfortunately do not do my own tuning- so ill have to set it up and then take it to be retuned on the dyno with the new MAP and increased boost and fuel pressure-
So should I set the base FP to 70 ?
Old 01-29-2013, 01:38 PM
F110Mech's Avatar
800rwhp with E85?
Quick Reply: Dual external Wally 255hp on E85 base fuel pressure
