O ring heads and not use ls9 gaskets? or use ls9 gaskets?
Old 02-03-2013, 06:03 PM
703 CAMAROSS's Avatar
Default O ring heads and not use ls9 gaskets? or use ls9 gaskets?
What do you guys think would be best, o ring the heads and use a copper gasket? Or use the ls9 head gaskets? I'm going for 1000rwhp with an S88 and 390. The heads are 317's btw.
Old 02-03-2013, 06:36 PM
deeloc1's Avatar
Ls9. Guys have done it already.
Old 02-03-2013, 06:40 PM
I have ls9 right now but I'm not sure which would stop me from pushing coolant better.
Old 02-03-2013, 07:55 PM
djfury05's Avatar
LS9 gaskets and ARP studs.. IMO don't waste money with o-ringing the heads unless they are an aftermarket casting later in the future.
Old 02-04-2013, 07:41 AM
Closed ex-Sponsor Account
JHR Performance's Avatar
I have personally ran 25 PSI with LS9s on stock decked heads and standard ARP head studs. This is with E85 and no intercooler. 285+ Degree IATs. You should be just fine with just the gaskets.
Zach
Old 02-04-2013, 08:08 AM
That makes me feel better! Was this on a dyno or on street/track?
Old 02-04-2013, 08:42 AM
Reject's Avatar
Zach, what size blowwer was the 25 psi from?
Old 02-04-2013, 03:31 PM
TheLS1Lover's Avatar
Unless you feel like swapping out the Head Gaskets every 1,000 miles or so I would do the LS9 Gaskets with ARP Studs (Maybe L19s).
Old 02-04-2013, 09:50 PM
bad6as's Avatar
Hke built engine, iron block, tfs cnc heads, ls9 gaskets,and arp studs. 25psi borgwarner 80mm and 15* timing, maybe 7 1/4 passes over 150mph at just under 3330lbs. Tons of street pulls. Engine been going hard for 3 years, no issues to speak of, the new turbo will put the 4 bolt block to the test
Old 02-04-2013, 10:06 PM
fastsspr's Avatar
Good you know because i plan to use Ls9 gaskets with arp studs too.
Quick Reply: O ring heads and not use ls9 gaskets? or use ls9 gaskets?
