Help on a formula to tt my nissan 240sx ls powered
Ok so basically I was wondering if someone here can help me out and come up with a formula to twin turboing my nissan 240sx.
I plan on using these headers right here.
Now my aim is
Stock bottom end boosting at 6-9psi
Hp I'm wanting is a big range from 6-800
Nice small turbos(since my bay is no way near as big as the fbodies or gto's
What I have now
04 gto block
Stage 2.5 prc 243 heads
I believe ls7 lifters
Monster stage 3 clutch
Brand new steel flywheel
96mm typhoon(don't hate) opened to a 102mm
102mm nw
43 lb injectors
Walbro 400
-6 fuel lines
Stock PCM
Tourqer v2 cam
I believe that's it but I'm sure in leaving stuff out
I'm trying to keep it reliable so I really only want to boost at 7-8 but a range from 6-9 is fine
Now my aim is
What I have now
04 gto block
102mm nw
43 lb injectors
Walbro 400
-6 fuel lines
Stock PCM
Tourqer v2 cam
