denmah's commonly bought turbo car items (update 7-11-16)
Old 01-21-2015, 01:14 AM
  #481
Sumter's Avatar
Originally Posted by fastcars95
I cant find an 04+ head studs anywhere. Where are you guys buying them?
Contact Jason from Alper Motorsports. I picked some up from him a week or so ago.
Old 01-21-2015, 08:54 AM
  #482
Moderator
denmah's Avatar
Originally Posted by JustAFooL
Denmah, where do you get the wastegate springs at for the 38mm Emusa? Mine came with just one and is like to get a couple. Maybe 14# and one a little higher
i have a bunch from ordering gates, and getting a few springs, but nearly any springs will fit in the china gates, im pretty sure you can buy the spring sets online let me check
Originally Posted by Sevex
What's everyone's stance on new timing sets.
Going to be swapping my cam out soon, does everyone use the stock timing gears/ chain or do you guys get new ones?
i always use stock timing set, even on 270k mile engines
Old 01-21-2015, 08:55 AM
  #483
Moderator
denmah's Avatar
yeah i see springs all over for like 10 dollars to 30+ for tial springs
Old 01-22-2015, 06:34 PM
  #484
Y2K_Camaro's Avatar
I dont know what some of you are using for transmissions. But I'm backing my 5.3 with a th400. I did a search and didnt really find a clear enough answer. So what kind of stall converter do I need to buy? One for a th400 or are there special ones I have to buy made for a LSx/th400?
Old 01-22-2015, 06:37 PM
  #485
Sumter's Avatar
I'm running a TH400 Revmax converter with a flexplate spacer
Old 01-22-2015, 06:39 PM
  #486
Y2K_Camaro's Avatar
Ok cool. So it's just a normal converter for a th400, right?
Old 01-22-2015, 06:43 PM
  #487
Sumter's Avatar
Yeah it's just a normal TH400 converter
Old 01-22-2015, 07:19 PM
  #488
Y2K_Camaro's Avatar
Ok got ya. Thanks man.
Old 01-25-2015, 03:28 PM
  #489
Sevex's Avatar
Ok another question for the 4l80e guys, planning on making around 700-750whp, what flexplate are you guys using? Is it worth stepping up to the SFI plate or can I stick with the stock replacement (going in a 5.3 so I got to swap anyway)
Old 01-25-2015, 04:28 PM
  #490
etijsma's Avatar
Where do you find the cheap ones? I need 2 of the smallest ones possible for tial f38's, got any?
Old 01-26-2015, 07:35 AM
  #491
ckanderson's Avatar
Yea id like info on this as well, sticking with the stock converter for now, so i need to know what i need to mate up a 4l80 to a 5.3
Old 01-26-2015, 07:50 AM
  #492
ryanleiker's Avatar
Also on this note, whilst investigating the stock replacement 4l80e flexplate, I found listings for ones "with spacer" and "without spacer"...
My buddy's 5.3 has no spacer, obviously, but how do I distinguish which stock version he will need to mate his 4l80e with stock converter to his 5.3?
Are the rears of the crankshaft identical, in which case if you would simply go with the 4l80e flexplate without spacer?
Maybe we'll just try them both when the time comes and report back... they're both readily available.
Old 01-26-2015, 08:28 AM
  #493
ckanderson's Avatar
Doing research on this site
http://www.performancetrucks.net/for...-shaft-523491/
says that this flex plate will work, and its a hell of a price
Amazon.com: ATP Automotive Z-270 Automatic Transmission Flywheel Flex-Plate: Automotive Amazon.com: ATP Automotive Z-270 Automatic Transmission Flywheel Flex-Plate: Automotive
Old 01-26-2015, 10:15 AM
  #494
Restricted User
JoeNova's Avatar
I had to use a 6.0 flexplate with a spacer on my 5.3. If it has the short crank, it will need the spacer to work with a 4L80e. I'm not sure any of the 5.3s ever had the long crank.
The spacer is a separate piece from the flexplate all together. I'm not sure if the flexplates made to use with or without the spacer are any different.
Old 01-27-2015, 12:55 PM
  #495
Sevex's Avatar
The one from ATP was the stock replacement that I was looking at, my question though is would you feel safe running in behind 750whp?
Old 01-27-2015, 02:56 PM
  #496
ckanderson's Avatar
others have run stock ones to that power level, so why not?
Old 01-27-2015, 10:06 PM
  #497
Sevex's Avatar
I would love to run it instead of paying 200+ for a SFI plate, just wondering if others have had issues with stock plates at that power level, if not I will order one right now
Old 01-28-2015, 01:43 PM
  #498
roastin240's Avatar
Need to acquire a 2 bar MAP sensor for my low boost setup on my S10. I assume the link below is a knockoff sensor rather than the typical AC Delco one everyone runs (12615136). Anyone ever run these ebay versions with success?
http://www.ebay.com/itm/NEW-GM-Camaro-Firebird-Corvette-LS1-LS6-LSX-2-Bar-MAP-Manifold-Sensor-12615136-/181167476216?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a2e6c4df8&vxp=mtr
Old 01-28-2015, 02:24 PM
  #499
Moderator
denmah's Avatar
i use this map all the time, i would recommend if you are going to boost, might as well get the 3 bar even if you are only doing 14psi, youll have the room to grow down the road...
http://www.efisource.com/shop/ls1-st...ar-map-sensor/
Old 01-28-2015, 02:44 PM
  #500
ryanleiker's Avatar
New GM Camaro Firebird Corvette LS1 LS6 LSX 2 Bar Map Manifold Sensor 12615136 | eBay
Is your tune already setup for 2-bar MAP? If not, just run the 3-bar from efisource.com. It's been statistically reliable in a lot of builds, including my own. And it's got a great price.
Quick Reply: denmah's commonly bought turbo car items (update 7-11-16)
