denmah's commonly bought turbo car items (update 7-11-16)
Old 02-07-2013, 01:56 PM
Moderator
denmah's Avatar
i added the scanvenge pump i use, turbo werx to the main post, and ill grab the JDM sport stock elbow i use
Old 02-07-2013, 01:57 PM
Moderator
denmah's Avatar
3" to 3.75" 90 Degree Reducer Silicone Coupler Black/RD
http://www.ebay.com/itm/3-to-3-75-90...4d8ba4&vxp=mtr
Old 02-07-2013, 02:01 PM
Moderator
denmah's Avatar
i added the 2.5 and 3 inch to 3.75 inch 90 couplers i use they fit the stock truck and ls1 throttle body great
Old 02-07-2013, 02:51 PM
lxwithlaundry's Avatar
If I ever loved a man that wasn't my daddy its you Matt hahaha.. (no homo) you make it so easy for us... can't thank you enough...
Old 02-07-2013, 02:54 PM
Moderator
denmah's Avatar
i know this is also super fancy, but i wanted to try this for how cheap it was, and see if it worked, since my truck had the oil cooler i couldnt easily drill and use my oil thing above the filter...
http://www.ebay.com/itm/271140973859...84.m1497.l2649
threw that on and it works great.
Old 02-07-2013, 03:02 PM
Sumter's Avatar
i'm using that same oil adapter plate
Old 02-07-2013, 06:26 PM
Sarg's Avatar
Anyone tried the On3 scavenge pump yet? $150!
Old 02-07-2013, 06:39 PM
Speedy911's Avatar
Originally Posted by denmah
i have had great luck with CXracing parts, intercoolers, and turbos.
i actually used CXracing turbo kit on my d series honda that came with everything and it was great.
for wastgates i like the ones viren sells. or just like this one
http://www.ebay.com/itm/300847355425...84.m1497.l2649
these are 13mm header bolts i recently swapped in since my truck had 4 broken bolts and i dont like the 10mm bolts
http://www.ebay.com/itm/140738027105...84.m1497.l2649
they work great also
Thats the wastegate I got thanks to Denmah!
Old 02-07-2013, 07:45 PM
Kory 88Iroc Lt1's Avatar
great info. Thanks for taking the time to make building fun stuff easy.
Kory
Old 02-07-2013, 10:35 PM
T76s10's Avatar
I could be wrong but i think that's the same exact white pump i used on my s10 last year. It pilaf exactly the same and cost me $150 also and worked great and flowed like 3.7gpm
Old 02-07-2013, 10:49 PM
02sleeperz28's Avatar
Hmmm...
Old 02-07-2013, 11:46 PM
  #32
JHall1975's Avatar
Thumbs up fuel lines/reg
Hi Matt,
What fuel lines/reg setup do you normally run on your LS builds? Are you running through the factory fuel filter/regulator (corvette style 58psi, returnless) or feed + return line with a boost referenced adjustable fuel regulator?
I'm looking forward to your new truck build with the factory PC/HP tuners. There is alot of us that want to go turbo but a little gun shy with some of the initial startup tuning/pump gas combos.
Thanks for your insight.
Jason Hall
1966 Chevy II 2dr 100 sedan
Old 02-08-2013, 12:36 AM
  #33
olespanky's Avatar
This is great I bookmarked it in my phone for when I order my micro squirt
Old 02-08-2013, 01:50 AM
  #34
Moderator
denmah's Avatar
Originally Posted by JHall1975
Hi Matt,
Jason Hall
stock truck regulator and return, honestly the best budget fuel feed if you are totally starting from scratch is to buy a 40 dollar -6an nitrous feed line, about 16-18ft can be had for that price and its robust and easy to install.
you can get those summit clips that go -6 strait to the top and bottom clip on the stock truck rails, i use the stock truck regulator too, even on big power setups 750whp.
for my fairmont i got the intake with no rails, and i didnt want to run returnless, and return were hard to find, ebay rails and an aeromotive regulator were actually pretty cheap.
something like a fox body car you can cut the feed and return, and then use rubber hose and connect to the stock feed and return clip on or also use push lock or something of the sort, and again put -6 fittings on them or get teh parker fittings etc.
on my truck i am using the stock tank, and rails and feed return etc.
i just installed twin pumps in the tank and 80lb injectors.
really i have done tons of fuel setups, all of them work too.
even still i know two people who run a feed up to the regulator, say a 2-4 port regulator with the return on the bottom, they run the feed into the left side, then they connect to the returnless fuel rail on the right side, and then return to the tank out the bottom like regular, this actually fills the rails and backs up into the regulator and works great for them.
conventionally you would run tank > pump > rails > reg > return
not sure what kind of options you are looking to do.
Old 02-08-2013, 04:57 PM
  #35
Sarg's Avatar
Well, giving the on3 scavenge a try. I will let you guys know how it works out.
Old 02-08-2013, 05:23 PM
  #36
redss82's Avatar
Should put the spacers and bolts for the injectors in here too so people dont have to ask you or dig for it
Old 02-08-2013, 05:43 PM
  #37
T76s10's Avatar
Sarg why do you need a scavenge? is your turbo mounted a little low?
Old 02-08-2013, 07:24 PM
  #38
GLS
GLS's Avatar
Bookmarking this! Great information for a first timer like myself!
Old 02-08-2013, 08:11 PM
  #39
SleeperZzZ28's Avatar
hope you dont mind, heres a few more
modular turbo's oil feed block
http://vtsql.gkvbf.servertrust.com/L...ck-p/cbr02.htm
alt relocation bracket
http://vtsql.gkvbf.servertrust.com/C...it-p/cbr01.htm
amazon has eboost 2 for $479
twin in tank pumps
http://www.airpowersystems.com/fbody...sgmf-fss01.htm
http://www.lonniesperformance.com/fbodyfuelsystems.htm
https://ls1tech.com/forums/fueling-i...ick-cheap.html
Old 02-08-2013, 08:17 PM
  #40
hy35f2t's Avatar
Would those injectors work with a tuned factory ecu? Its a 2001 truck motor with a custom made harness that will run 1999- 2006 truck motors. Sorry if it's a dumb question but I'm new to Lsx stuff and don't like to waste money.
Quick Reply: denmah's commonly bought turbo car items (update 7-11-16)
