Techline high temp coatings
Old 02-07-2013, 10:39 PM
80gus's Avatar
Default Techline high temp coatings
Any Comments/feedback on this product? the High temp black is what im chasing
Is there anyone in the us, that sells this that will ship to Australia??
Old 02-07-2013, 10:56 PM
Wicked69's Avatar
I think LS1Nova has used it with success. Not for sure. "search" threads with him in it and send him a personal message. I think he can help you out. Good luck.
Old 02-08-2013, 05:27 AM
LS1NOVA's Avatar
The black "Turbo X" is great. Sprays on easy and super tuff. It can be cured by engine heat or oven. Ive always used the oven. Check with Caswell Plating.
Old 02-08-2013, 06:03 AM
80gus's Avatar
I checked Caswell seems like you cant import this stuff without some licensing issues! such a shame as its listed on ebay.
Old 02-08-2013, 06:16 AM
typhoon1015's Avatar
I used the turbo X black, works good. I did have some spots where it ran and was a bit thick and that peeled off a bit. As long as its a smooth thin coat, and baked on, its good to go.
Old 02-08-2013, 03:04 PM
80gus's Avatar
Ive made a few calls seems the problem is you can not ship it by air, need to work out a way to ship it via sea.
Old 02-08-2013, 04:32 PM
V-seriesTech's Avatar
I just got a bunch of stuff for an F1x car build I am doing...everything looks AWESOME. Quality is better then what I am used to with my last coater(I do not know what brand product he used)..but the techline stuff looks amazing. Unfortunatly, I will not know how it looks after heat has gone through it. We also coated the catback with a textured finish(black)... I can get some pics up by the weekend of what I have. All in all, it looks like great quality. I can ask the company if they will ship
Old 02-08-2013, 04:38 PM
OkieDave's Avatar
Default tech line coatings
I've used them for years , multiple types of coatings. seems to be a good value to me.
Old 02-08-2013, 04:44 PM
SSZ
SSZ's Avatar
Can you use this stuff on exhaust manifolds? I used another spray on type of high heat coating, baked on and all, and the rust came through in about a month.
Old 02-08-2013, 04:47 PM
allout06's Avatar
would also like to know this. what about Exhaust housings on turbos? Ceramic coating is pretty expensive...
Old 02-08-2013, 07:10 PM
LS1NOVA's Avatar
Yes, works great on manifolds and housings. Its better to hit them with an 80 grit sanding wheel to knockdown the casting stubble so the coating doesnt flow off the little high spots.
Here is a set I did with Turbo X.
Old 02-08-2013, 07:19 PM
Boosted One's Avatar
I used the same thing. Works It has been holding up great on my manifolds, hotside pipes and turbine housings for few years now.
LS1Nova - what filler did you use to weld those manifolds up?
Old 02-08-2013, 11:18 PM
SSZ
SSZ's Avatar
I am going to have to find this stuff. Like i said, my other stuff was done by the directions with baking it and all. Do you guys ever have those cars outside in rain or moisture in the air. Mine isnt out there often and is usually is the dry garage but they still rusted. Kinda pissed me off.
Old 02-09-2013, 06:40 AM
LS1NOVA's Avatar
Used 309 on the Sch10 to the manifold. (for disimiliar metals) and 308 on the Sch10 to the SS vband.
Quick Reply: Techline high temp coatings
