Tial Wastegate Springs: rating vs actual
I have Tial 38mm wastegates running on spring pressure only. I have the large yellow (.7bar or 10.153psi) springs installed. Actual pressure (measured at the blowoff valve) max's out at 7.5psi. Is this typical? I've always used boost controllers in the past.
I'm sure spring fatigue, wastegate placement, vacuum source, excessive turbo/exhaust back pressure, wastegate sizing, and many other factors can influence it.
Where is your wastegate boost source coming from?
If spool and power seems normal and it is consistently doing that, I wouldn't be too worried about it. You have three choices, shim it, get a bigger spring, or throw on a boost controller.
Dang it! Tial shouldn't refer to there springs in PSI ratings then. They should simply state the spring rate or some other system of description if they want to keep the rate a secret. Technically, I just wasted money on the springs then. While the turbos were out, I put in the higher rated spring and uninstalled my electronic boost controller since I figured I would never increase the boost and an EBC is just one more thing to fail. Oh well, since the waste gates are such a pain to get to on my setup, I guess an MBC is in order.
Tial springs are rated correctly.. Your porting on the gate port/turbine housing will skew the results big time.. Not to mention your exhaust system after the turbo (aka back pressure).
On my bike with a short dump pipe (no restriction), here is what I see win various Tial springs:
Small red, 5.8lb : 6.00 psi
Big yellow, 10.15lb : 8.8-9.2 psi
Big blue, 14.5lb : 14.5 psi
Logged boost on two different map sensors... Identical results.
For the engine: certain fuel type, power at the crank, no accessories, etc
For the Bow: 70lb draw weight, 30in draw, 350 grain arrow, ....
For the steel: annealed at 865 deg C
