stand alone waste gate . possible ?
Can a person run a stand alone waste gate with out a controller, and if so, do they make one that is manually adjustable ?
I want to find my desired boost pressure and just leave it there without having to worry about a controller.
Is this a possibility or do I need to run a controller ?
Im looking to run somewhere between 7 and 12 lbs I think .
Yes you can run a wastegate without a boost controller. The prssure is set by the spring inside. So to change the boost level without a boost contoller, you will need to swap springs. There are some adjustable wastegates on the market, but I personally have no experiance with them. I don't trust their design. I feel by adding more preload to the spring, you are also decreasing the overall amount it can open. Thats all for external gates at least. Internal gates can easitly be adjusted but changing the length of the rod. I would just get a manual controller though. They are cleap and easy to use. Remember though, you can never run lower boost than the wastegate is set at. Boost contollers only increase the boost above that.
So, I can assume, this shud work for all waste gates,,Ive got a turbo smart one coming....and I dont really want a controller, if I can get by without it..
and yes a 7675 turbo for a ls engine..
When you say controller, do you mean electric controller, or manual controller? Manual boost controllers are simple and cheap, basically they are just bleeder ball valves.
You can DIY one for cheap, google DIY MBC and you will get lots of hits.
If you want NO boost controller at all, then ignore.
Chosen spring pressure will approximately equate to your desired boost level, but there are many factors that can influence it
And yes you need to run a signal line from a boost source to the wastegate. In effect that is the primary control method.
This can be played with to increase desired boost pressure, and can be done so very easily. WHich is why it's often preferred to choose a slightly softer spring, and then bleed off to your desired boost pressure
