Super Victor intake / air distribution.
I've been researching intake manifolds for my LSX 427 turbo with TEA/TFS 245 heads.
I have been considering a Edelbrock Super Victor, Pro Flo Xt, Holley Hi Ram.
The engine is for a GTO/ Holden Commodore and I think the Hi Ram will sit extremely high and require a large cowl and I'm not a fan of this look.
The Pro Flo only has a 90mm opening for a throttle body and looks like would be difficult to port for high H/P.
The Super Victor with a good elbow is regularly used for boosted applications and although It sits high with the elbow it would be easier to cover with a hood bulge or something like that.
Now my question is why do so many high horse power set ups use this style of intake manifold but most people say they are bad because of the poor air distribution?
What are the high H/P guys doing to their intakes to make them work?
Cheers.
Cheers.
https://ls1tech.com/forums/forced-in...em-solver.html
look for my post and go to the link on yellowbullet and read that thread. alot of things to be learned
my opinion would be to do everything you can to get a high ram to work if your trying to save a little money but if you have the money it be well worth it to get a sheet metal on for your setup
almost all of them run them because they saw another guy running them honestly. it is far from the best intake you can get for the money
or that the vic jr has air distribution problems? or is this just regurgitated hear say?
people dont say the super vic is bad because of air distribution
most people say the vic JR is bad because they read that online someone. these are people who have never even seen one in person.
you know you cant put anything online that isnt true, so if someone says it then its a fact.
i dont see a lot of high hp cars using this setup
A Super Victor is a better intake than the Victor Jr, and the Holley High Ram seems to be better than either of those in forced induction application.
I have distribution issues with my super victor. It is hogged out to the max on both cars. The plugs look different on every cylinder. I will be pulling plugs after 1st time out this year. My BS3 can change fuel and timing in each cylinder individually. I will have to use this quite abit.
We had a GM carb style intake a few years back and we had to change every single cylinder to get it better in the combustion chamber.
Either way, you don't really know unless you pull the plugs. Even on a forced induction situation.
It all gets a bit confusing with so many different opinions out there and when you spend a fair amount of money on the rest of the engine you don't want to destroy it because you made a poor manifold choice that's for sure
Personally I wouldn't do a High Ram unless you plan on buzzing it high, say 8500+. If you look up KoolRayz he runs a AllPro 2-Piece Intake, and has gone 7.30s with a 88mm Turbo. Unless you go to a Marcella the Super Victor would be my choice.
I run a standard victor jr since 2006 now, never noticed a problem with the distribution that concerned me. 30 lbs of boost and 1500 rwhp through at TH400.... I study my plugs after every event... fresh plugs, pull and read. I do tune conservatively too.
The cylinder distribution is an issue on cars that are pushing the limits and need pin point accuracy on all cylinders with a PCM that isn't capable of handling individual cylinder adjustments. I ran a ported Vic Jr on my 403 with a 4150 Accufab TB and the cylinder distribution on it was horrible.
Sure you can tune in some error on the rich side so that the lean cylinders aren't to lean to keep average setups together but when you start pushing it on the edge of a certain fuel octane or hard parts you'll find out quick that the intake is one variable that I don't want as a variable. The tunnel ram style intakes don't have the distribution issues the single planes do. Equal length runners plays a huge role there.
If you look at a Vic Jr the middle 4 cylinders have alot shorter runner than the outer 4 cylinders do. This runner differences changes the VE of the cylinder. If you have individual cylinder control like most big setups do then it's a non-issue because they dial in fuel per cylinder with multiple widebands, plug readings and EGT gages.
I will say the Super Victor isn't nearly as bad as the Vic Jr.
I have read that the ideal plenum size should be the same as the engine capacity ie 427ci= 7.0L plenum volume, does anyone know what the plenum volume is on the pro flo and hi ram?
Also I found a photo with the top of a pro flo cut off, I don't know if it was to port it, enlarge the plenum or enlarge the inlet opening for a bigger throttle body.
Has any one seen this type of modification before or have a link to any threads.
Thanks
Thanks
