Borg Warner Turbochargers - Huron Speed
Anyone in need of the ever popular Borg Warner turbos, be sure to contact Huron Speed!
With our new T6 Turbo Kits coming to the market (5 kit builds underway at the moment!) we are hooked up to be able to supply customers with very reliable, affordable, and effective BW units!
We can get anything from a T4 framed S480 to an 88mm wheel'd Race cover T6 S480. If there is a Borg Warner turbo that you are interested in, contact us and we would be more than happy to get you set-up with it as well as any other Turbo component or even a Custom Fabricated Kit for all of your turbo needs!
And some fun pictures for everyone to enjoy!
S480 with the 88mm wheel!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Better Better get an aluminum slug to reinforce the cover. The turbo wheel will suck in the thin walls, I have done it.
In all honesty for a rear mount application, one of these larger BW units will be difficult to package in the rear of a C5 due to the physical size. I think a pair of twins would be much better suited out back there!
__________________
__________________
That is a Hurricane Series!
__________________
These things are so affordable i think i might turbo my lawn tractor!
but for real these things are affordable. shoot us a pm. you'll be surprised!
-Casey
-Casey
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
TWITTER @HURONSPEED
TWITTER @HURONSPEED
Yeah, we can make anything you like!
Shoot me a PM for details!
__________________
It depends on the turbine wheel used.
I like to use the 92mm turbine wheels on just about everything other than a 4.8. I'll then size the AR housing accordingly to the cubic inches of the motor to achieve the spool time I need.
Example:
5.3= S475, 87mm or 92mm turbine wheel 1.0 AR housing
5.7= S475, 92mm turbine wheel 1.10 AR housing
6.0/6.2= S475 92mm turbine wheel 1.10 or 1.25 housing depending on other characteristics of the build i.e. is it a M6, A4...will it be mainly street driven or raced etc.
Example:
Example:
Example:
Thanks for all the inquiries everyone! We are working on the T4 quotes at the moment and I will get with you ASAP on them!
Jon
Jon
__________________
