The Vanilla Gorilla! LQ4, xt80, 97' RCSB Chevy on Propane! Update! Track Times!
Old 02-19-2013, 12:31 AM
Turbo D's Avatar
Default The Vanilla Gorilla! LQ4, xt80, 97' RCSB Chevy on Propane! Update! 10.91@126!
Thought I'd post up some pic's of my turbo propane truck project. It's a 97' Chevy 2wd RCSB originally a 4.3l/4l60 truck. Here are the specs:
2003 6.0l LQ4 with unknown miles
Z06 cam and springs
Vic jr intake + 6010 msd box
Dual Impco 425 mixers with dual Spectre Carb hats
Magnum XT80 turbo 1.15 ar exhaust housing 4" down pipe
th400 3600rpm B&M converter
It's pretty close to being running, should be running in the next week or so. Thanks for looking!
Grampa fresh
Engine in, mixers and converters mounted
Mark7 fan mounted on a dual pass be cool rad
Single in, dual out intercooler
Turbo mounted, 4" downpipe tacked up
Upper intercooler pipes done, dual BOV's rad mounted etc.
More pics to come this week!
Old 02-19-2013, 12:43 AM
Moderator
denmah's Avatar
whoa!
Old 02-19-2013, 01:35 AM
67Firebird455's Avatar
Now that is man ****! LOL That's a new one for even Denmah! =)
Old 02-19-2013, 02:00 AM
91sonomast's Avatar
Turbos and propane?!? This sounds like a blast! A little bit literally lol
Old 02-19-2013, 05:48 AM
Sarg's Avatar
In for updates. Very different build.
Old 02-19-2013, 09:15 AM
js2fst's Avatar
You always octane for cheap we just picked up our propane truck
Old 02-19-2013, 11:57 AM
LSx64Chevelle's Avatar
You know you've got the good **** when you need to be licensed to fill your fuel tank.
Old 02-19-2013, 02:29 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
So badass.
Old 02-19-2013, 02:58 PM
Danny's Avatar
Very interesting build man. Definitely in for more updates.
How big of a tank will you be running? I'm also wondering how long will a tank of propane last you.
Old 02-19-2013, 07:38 PM
Turbo D's Avatar
Ya the main reason I'm doing propane is because it's cheap, $2.00 a gallon right now and 105+ octane depending on what time of year. Mileage would be comparable to pump gas and the truck has a 35 gallon tank that sits in the box. I'll get some pics of it when I get it mounted. Here are some pics of the factory wiring that I thinned out "alittle"
Before:
After:
Old 02-20-2013, 06:47 PM
Turbo D's Avatar
Got my thermostat issue figured out last night, wanted a straight outlet instead of the angled housing trucks come with. Took a themostat housing from a 04' Savana Van with a 2 piece housing, cut it, rotated it and welded back together, worked perfect and way cheaper than a csr housing.
Perfect!
Old 02-20-2013, 07:05 PM
1969x11's Avatar
Wow another Charbroilet Grillberato!! Check out JohnMasters's build on Performance trucks. He's haulin *** on pane and boost.
Old 02-20-2013, 07:29 PM
1CAMWNDR's Avatar
That is kickass.
Question: Could those mixers and converters be mounted on a dual 4 BBL intake and work? Doesn't Edelbrock make a carb 2X4 intake for the LSx engines?
Old 02-20-2013, 08:20 PM
T76s10's Avatar
How the hell do you tune the fuel?
Old 02-21-2013, 03:33 PM
Turbo D's Avatar
Ya I saw the truck on there, gives me hope the dual mixer setup will be sufficeint on mine.
Originally Posted by 1CAMWNDR
That is kickass.
They could be, but i'd be worried about fuel distrubution with having everything seperate.
It has a WOT mixture screw and a idle mixture screw everything between is adjusted with different air valves, but as long as it has enough fuel at WOT under boost, I,m not to worried about the rest.
Old 02-26-2013, 07:54 PM
Turbo D's Avatar
Getting there, here are a couple of pics of the log header I made (crossover runs in front of the pan) the 4" DP and the full 4" exhaust with the biggest 4" Maganflow muffler they make.
Old 03-03-2013, 08:26 AM
kevin87turbot's Avatar
I'm really excited to see how this one turns out. You're basically running $2/gal race fuel! Keep us updated!
Old 03-03-2013, 10:01 PM
Turbo D's Avatar
Thanks, just got it running a day or 2 ago, took it for a rip and it seems to spool pretty fast. it's rich down low and lean up top so I have some work to do. I was going to mess with it more today but we got a foot of snow overnight so I'll have to wait to get it on the dyno. Here are acouple pics of the pretty much finished engine bay.
Old 03-03-2013, 11:03 PM
Turbo D's Avatar
Quick walk around video.
Old 03-04-2013, 03:15 PM
s-10ls1's Avatar
Sick build man!
Quick Reply: The Vanilla Gorilla! LQ4, xt80, 97' RCSB Chevy on Propane! Update! Track Times!
