Oil Supply/Return Locations for LS2 Turbo?
Old 02-19-2013, 02:38 PM
Zenki13.4's Avatar
Default Oil Supply/Return Locations for LS2 Turbo?
Hey everyone I was wondering if someone could help me out. I've owned and drove many turbo jdm vehicles in the past and I finally decided to put a ls2 out of a 2006 GTO into my 240sx. I am wanting to put on a turbo kit that enables me to make a realiable extra 100 hp without hurting my engine. I have a sikky aluminum oil pan and don't have any ports for a oil feed like the gto oil pan does, all I have is a in/out for my oil filter relocation kit. I was wondering where are some locations I can tap into a oil feed and oil return line to run my turbo? I know I can tap a return into my oil pan but I was wondering if there is any other locations and I am having issues finding where I can tap into a oil feed. Any help is much appreciated.
Cheers!
Old 02-19-2013, 08:32 PM
LS1NOVA's Avatar
Remove the stock oil sending unit from behind the intake and screw in a metric adapter to a 1/8npt to -4 fitting.
You can also tap into the front cover for the drain since that Sikky pan is sheetmetal and wouldnt tap so well. You could use a fuel cell bulkhead fitting really easy if the pan is off.
Im working on a 350Z with an LS and single 76 with a Sikky pan. I tapped the front cover on that one.
Old 02-19-2013, 08:42 PM
Zero_2_Sixty's Avatar
I am using this on my personal car -
It was made by Kurt Urban Performance. I cant find it on their website anymore though. You could always just tap where the oil pressure sensor sticks up in the back, which I have also done. The other option you have is using an adapter where the blockoff is right above the oil filter
Old 02-20-2013, 01:00 AM
Zenki13.4's Avatar
Did you use the oil sending port as your supply feed? And can you send pics where you tapped the front cover? Nice, what LS you got in her?
Old 02-20-2013, 01:05 AM
Zenki13.4's Avatar
Do you know what that fitting is called? That would be awesome to get my hands on.
Old 02-20-2013, 01:57 AM
westtexasbuff's Avatar
I'm using the stock oil sending unit location to a Y to both turbos, then used one of the side ports on the block for oil pressure.
Oil Supply/Return Locations for LS2 Turbo?-zt90k75.jpg
Old 02-20-2013, 04:30 AM
lysergic's Avatar
Does the PCM need to know the oil pressure for any reason. IE i have an aftermarket oil pressure gauge already. Is it ok to delete the factory sender and use that purely for turbo oil feed? Im in the process of fitting a comp 7479 to my 6L swapped 300zx
Old 02-20-2013, 07:33 AM
Zenki13.4's Avatar
Nice! Could you possibly send me a pic of the port you used for oil pressure. Pictures do me wonders. I'm used to coolant and oil ports bein all over the place on jdm engines.
Old 02-20-2013, 07:37 AM
Zenki13.4's Avatar
I'm pretty sure it doesn't but I'm not 100%, you can run an aftermarket gauge to monitor the oil pressure. What oil pan are you using? If your using a gto oil pan its easy to get a feed and return from it. Especially since yours and my engine bay are pretty open compared to some other vehicles.
Old 02-20-2013, 09:59 AM
There's only one port back there on the valley cover, you can't miss it. I used a M16x1.5mm to -4AN fitting, then just a -4 AN 90 to the line.
This is the fitting I used: http://www.ebay.com/itm/380557297694...84.m1497.l2649
Old 02-20-2013, 04:38 PM
Zenki13.4's Avatar
Thanks for the fitting link, I should have been more specific sorry, what side port on the block did you use for oil pressure and could I use the side port on the block for a turbo feed? Thanks
Old 02-20-2013, 10:08 PM
You can use any of the oil galley's in the block... there's one on the passenger side right above the starter, and two on the driver's side; one on the bottom to the rear, and one in the front right near where the alternator goes (in stock location). Any one of these can be used for oil pressure or oil feed. They are all the same thread; M16x1.5mm.
Old 02-20-2013, 11:46 PM
Zenki13.4's Avatar
Perfect thanks!
Old 02-20-2013, 11:47 PM
Zenki13.4's Avatar
I was thinking of going with the efi live tune for my car. Has anyone used this product and can you tell me what they thought?
Quick Reply: Oil Supply/Return Locations for LS2 Turbo?
