turbo k member
Old 02-22-2013, 08:55 PM
1BadAsZ's Avatar
Default turbo k member
How many folks run a turbo k member? Is it essential with certain setups or will most of the tubular k members work
Old 02-22-2013, 09:43 PM
607motorsports's Avatar
It really depends on the setup you go with the biggest issue is the clearance for routing a downpipe back through the K. I'm running a PTK turbo kit with a TC78 turbo and am still retaining the stock k-member.
Old 02-23-2013, 08:43 AM
1BadAsZ's Avatar
More then likely it will be a forged 5.3 and a 80-88mm or so
Old 02-23-2013, 10:21 AM
F110Mech's Avatar
Get the Mid West Chassis K-member. it's not a "turbo" K-member but from what I read itll fit a 5" down pipe. I got it for weight reduction as I'm going to be running an S400 with a 5" DP out of the side of the bumper
Old 02-23-2013, 11:15 AM
1BadAsZ's Avatar
Ok thanks I'll look it up. Just curious, I've seen that turbo mentioned a lot which means its pretty good or cheap lol. How much hp is it capable of
Old 02-24-2013, 12:39 AM
Toxic-Evo's Avatar
The new DKT/bmr one will fit a 5" plus.
Old 02-26-2013, 08:14 AM
97FormulaWS-6's Avatar
Location: Land of the Mormon's although I'm not one of them
I believe each side will fit a 5" downpipe on the DKT/BMR one if you really want to go *****-out.
Quick Reply: turbo k member
